Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 12-26-2021, 04:41 AM
Zergei72 Zergei72 is offline
Default Beat Bars MIDI Expression Pedal EX3
How can I enable automation data in order to control Amplitube's WAH, etc ; Or the WAHs in POD Farm 2 .
I've tried every way possible, but something's not there yet .
The Pedal shows up in MIDI Input Devices, but that's all I get .
Some clearance here ; THANK YOU .
- Z -
Old 01-16-2022, 09:55 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Beat Bars MIDI Expression Pedal EX3
- Z -
Hi, Can you tell if Pro Tools is getting any MIDI data from your pedal? You should be able to create an Instrument track and enable Record to check. Have you checked that your Instrument I/O in the Mix/Edit windows is correct?
I've used a Vox Tonelab to trigger MIDI in Amplitube with no problem.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Quantize midi bars to beat markers EagleEye5 Tips & Tricks 0 07-02-2020 02:37 AM
Using Expression Pedal (Wah) Bryancole412 Eleven Rack 2 05-22-2016 07:58 PM
Midi Footboard Expression Pedal (CC 11) and External Footswitch Mutally Exclusive? mattz63 Eleven Rack 1 07-14-2015 09:11 PM
ErnieBall VP Jr Volume Pedal as expression pedal. cohensm Getting Started 7 07-06-2014 07:48 PM
Expression pedal with PT8 phiffdawg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-03-2011 08:29 AM
