Old 11-05-2017, 01:16 AM
Rockman413 Rockman413 is offline
Default Is SPDIF sound quality identical as ADAT?
I understand they are both digital and technically digital should be exactly the same. If a sound goes thru SPDIF from one audio interface and record into another audio interface (Pro Tools HD), is it the same as it go thru ADAT? Did anyone actually test it and hear it with analogue ears :)?
Your experience?
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 11-05-2017, 01:34 AM
Sardi Sardi is offline
Default Re: Is SPDIF sound quality identical as ADAT?
Mods... please put us out of our misery and do what needs to be done.
Old 11-05-2017, 04:19 AM
Burbree Burbree is offline
Short answer: no, use decent cables for either format and you'll be fine.
Long answer: ADAT format is based on Toshibas TOS Link which at a software level is essentially an optical version of the S/P DIF format. AES/EBU, S/PDIF and TOS Link all share a similar bitstream format, and the clock is encoded with the data signal. Some mastering engineers however postulate that there is some line induced jitter introduced by the air between the two ends of the optical interface! However a long run of optical digital signal is likely to outperform a cabled version. In conclusion: use correct impedance cable with decent connectors and keep runs short when using S/P DIF (75 ohm) or AES/EBU (110 ohm) , and decent optical cable when using ADAT/TOS Link and you'll never have to lose sleep over whether one is better than the other.
_____________________________________________
Pro Tools 2018.12 - MacBook Pro 2.8 GHz i7 Mid 2015 16 GB RAM 1TB Flash SSD - macOS 10.13.6
Pro Tools 2018.7 - 0db Hackintosh 4.0 Ghz i7 32 GB RAM 256GB Flash SSD - macOS 10.12.2
Old 11-05-2017, 09:43 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
When you say long runs, what sort of distance are you referring to?
I use AES as my standard digital I/O if that helps you with an answer for me.
What is more relaxing then Music?
GigabyteX79-UP4 Rev 1.1
Xeon E5 2680 v.2. 10 Core cpu Windows10 v.1909
Avid HDX 2019.10 HD - 16x16 - 8x8x8 HD I/O - PT Dock - PT Control - AVID Artist Mix (2)
Universal Audio UAD2 Pci-E and Satellite USB Octo - Pci-E Quad - SOLO 610 - Twin-finity
Antelope Trinity - 10M
Grace Design M905
Bricasti M7 (2)
Lexicon PCM96
Burl B2
Dangerous 2Bus
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Etc, etc, etc.
Old 11-05-2017, 10:28 AM
Somebody just trolling DUC. He needs to be given a DUC vacation...
Old 11-05-2017, 10:53 AM
Carl Kolchak Carl Kolchak is offline
I think a lot of people forget that most of our internet data, and streamed entertainment, gets around the world via the transatlantic cable.
Old 11-05-2017, 10:58 AM
john1192 john1192 is offline
i 2nd the motion !!!! this is getting pretty silly .. thread after thread ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 11-05-2017, 11:32 AM
Thanks. When you say decent cable, currently I use Hosa adat cables and SPDIF cables and monster pro SPDIF cables. Do you think they are fine or any other cable is better?
Old 11-05-2017, 12:10 PM
JFreak's Avatar
JFreak JFreak is offline
As long as digital signal goes through, it is 100% clear. The difference between SPDIF/ADAT/AES is in now long cable runs you can do before you get dropouts. As long as everything is perfect, who cares which format delivered it?
Janne
Old 11-05-2017, 12:30 PM
Do >I< think they are fine? YES!
There's some fascinating (or boring however you view it) rabbit holes you can dive down should you wish to read up on the lengths that some people go to "improve" their sound regarding jitter induced by S/P DIF, USB, Logic buffering, cable length, circuit board trace spacing, the list is nearly endless..
better quality power cable = better quality sound? dbvoyager General Discussion 22 04-15-2012 06:08 PM
mono like sound from spdif out (GA-EX58-UD3R) to spdif in (Omni ) chrisdee Pro Tools HDX & HD Native Systems (Mac) 9 04-02-2012 05:10 AM
Poor quality MBox 2 SPDIF out signal. danlea 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-05-2011 08:08 PM
Using adat optical to get another quality A/D? VK$$$ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-03-2002 05:12 PM
88/20 vs ADAT bridge Sound Quality... mixtery Tips & Tricks 2 07-21-2000 04:12 PM
