Old 09-07-2017, 03:07 AM
Achim_Kiel Achim_Kiel is offline
Default Shortcuts "toggle track view" not working
Hi out there,
I'm running PT 12.8.0 on OS X Sierra 10.12.6., set up 2 weeks ago.
The shortcuts for toggling track view "-" and "option -" are not working.
When I hit "-" the curser moves a step forward, depending on my nudge value. When I hit "option -" nothing happens. All other shortcuts I use work properly.
What am I missing?
Thankx in advance for help!
Achim
Old 09-07-2017, 06:49 AM
Burbree Burbree is offline
Default Re: Shortcuts "toggle track view" not working
Make sure this setting is on
File Type: png Screen Shot 2017-09-07 at 14.46.32 1.png (6.4 KB, 0 views)
_____________________________________________
Pro Tools 2018.12 - MacBook Pro 2.8 GHz i7 Mid 2015 16 GB RAM 1TB Flash SSD - macOS 10.13.6
Pro Tools 2018.7 - 0db Hackintosh 4.0 Ghz i7 32 GB RAM 256GB Flash SSD - macOS 10.12.2
Old 09-07-2017, 06:50 PM
cshaw cshaw is offline
Also make sure you're hitting the "-" above the "p" key; using the "-" key on your keyboard's number pad won't work - that's for nudging
www.chrisshawmix.com
PT 20.3.0
S1
Artist Transport
Avid Control
iPad 7th Gen
HD Native
Hackintosh i9 3.6 GHz Six Core
Apogee Ensemble
OSX 10.13.6
Old 09-09-2017, 01:21 AM
Thanks - that put me on the right track. I'm using a german keyboard, and while e.g. "control z" works as expected although the letter "z" is not at the same place as it is on an american keyboard, "-" doesn't. I hit the Key where "-" is on the american keyboard - voila!
Change Track View "vol" or Pan parameter only on selected Tracks joachim Tips & Tricks 0 12-03-2015 07:05 AM
Hotkey for "toggle track view" jeremyseanbell macOS 4 03-11-2015 08:42 AM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
Toggle Track View not working (waveform/volume/etc) Imgoinmad Pro Tools 9 4 11-24-2010 04:35 PM
Toggle Track View on all tracks KC not working tokolosh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-27-2009 09:13 AM
