Old 04-26-2019, 12:00 AM
GOOOTOOO GOOOTOOO is offline
Default Setting tempo to length of a sample
A lot of my current projects start out with a ripped drum loop. It would be really convenient to be able to just set the tempo to the length of a sample. Right now what I do is find the length of the sample then use a calculator to find out the BMP and set it to that, kind of seems unnecessary.
Old 04-26-2019, 12:21 AM
Sardi Sardi is offline
Default Re: Setting tempo to length of a sample
Identify Beat is what you want.
Old 04-26-2019, 03:25 AM
Burbree Burbree is offline
Put Bar 1 Beat 1 of the sample on Pro Tools Bar 1 Beat 1
Tab to the transient of the samples Bar 2 Beat 1
Identify Beat or Command + I
Type in Bar 2 Beat 1 (2 | 1 | 000) in dialog box
_____________________________________________
Pro Tools 2018.12 - MacBook Pro 2.8 GHz i7 Mid 2015 16 GB RAM 1TB Flash SSD - macOS 10.13.6
Pro Tools 2018.7 - 0db Hackintosh 4.0 Ghz i7 32 GB RAM 256GB Flash SSD - macOS 10.12.2
Setting record length VOWizard Pro Tools M-Powered (Win) 0 12-19-2015 10:22 PM
Setting of 'Edit Window Default Length' critictalk Tips & Tricks 1 07-30-2013 10:39 PM
Region length and tempo alignment rossco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-21-2006 12:15 AM
Setting tempo to match a hit or set length tlester Pro Tools TDM Systems (Mac) 1 03-02-2006 03:56 PM
Qusetion about setting recording length time Cliffy_Boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-25-2003 04:49 PM
