Multiple ProControls on a common Ethernet Hub
I am experiencing a situation where I have 2 Pro-Control systems on a common Ethernet network and therefore I can "see" all MainUnits and all FaderPaks of both ProTools systems in either "Periferials" window on each ProTools program.
Are all MAINUNITS and FADERPAKS given a unique address at the factory and/or can we(the end-user) set unique addresses of any of these units. |
Re: Multiple ProControls on a common Ethernet Hub
R. Austin
To use multiple Procontrols on one ethernet hub, set up ethernet zones for appleshare for each or the Procontrols, then select that zone in the Chooser. MJ Digidesign tech Support |
I understand your reply but it doesn't satisfy my requirements nor have you answered my question. I'll try to better explain the situation . . . To enable each of the Macintosh computers (that are host to a Protools/Pro-Control program) to share communication with a commmon Video Server system via ethernet we are uplinking from each Pro-Control's ethernet switch to an ethernet switch feeding the Video Server. It is across this path that the Pro-Controls are "communicating". The Video Server is a common (single) "Zone" and is required. Further, I expect to be adding more Pro-Control systems into this combination in the near future. We know at this point that each of the units that we have purchased to date have some form of address - as witnessed on the lower display/4th and 5th position of the fader packs and MainUnits and that this address is unique (different). If we can get a confirmation from Digidesign that these addresses are ALWAYS unique, then by appropriately naming every MainUnit and FaderPack we can control this situation. I repeat, Are all MAINUNITS and FADERPAKS given a unique address at the factory and/or can we(the end-user) set unique addresses of these units. Of course, the ideal situation would be if ProTools had the ability to "hide" certain MAINUNITS and FADERPAKS from the other systems via the peripherals window. NOTE: About 10 minutes after I posted this note I received a phone call from Chris at Digidesign that answered my questions about the address numbers. Thanks guys ! <BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by TechSupt: R. Austin To use multiple Procontrols on one ethernet hub, set up ethernet zones for appleshare for each or the Procontrols, then select that zone in the Chooser. MJ Digidesign tech Support<HR></BLOCKQUOTE> [This message has been edited by R. Austin (edited September 13, 2000).] |
what ethernet switch are you using for multiple MC units on a Mac | snake doc | Artist Series | 5 | 07-07-2010 02:57 PM |
Connect 2 or more ProControls in one computer ? | thk | ProControl, Control|24, Command|8 | 4 | 05-12-2004 04:45 AM |
Advice on used ProControls | AE | ProControl, Control|24, Command|8 | 5 | 04-15-2002 04:51 PM |
networking 2 PT sys (with ProControls) ? | sonicsam | ProControl, Control|24, Command|8 | 3 | 09-07-2001 09:01 AM |
New ProControls | uno1234 | ProControl, Control|24, Command|8 | 5 | 03-26-2001 10:05 AM |
