Re: new procontrol user... help!
Greg Malcangi
Thanks, you are correct, as stated in the manual you need to use the supplied red labeled crossover ethernet cable for use with Procontrol connected directly to the CPU ethernet connector. MJ Digidesign Tech Support |
MJ,
Voodoo is never an issue for the people who wrote the damn program! For us mere mortals it's another story. Anyone know how to find a good live chicken supplier? ------------------ Angelo Quaglia AQ Productions
Cheers, Angelo Quaglia |
I can't seem to move from my computer! Someone must have put a spell on me!
Jules |
Are you all saying that you have appletalk on for using your ProControl?
I NEVER have appletalk switched on unless I need to do file sharing between other macs. I find that it slows down my ProControl. I was under the impression that all you need is the apple ethernet extension. My 16 channel system works perfectly without appletalk. How come Digi Tech Supp? This needs to be clarified for these people methinks. Tweakhead. |
so... problem solved... it was all the AIRPORT card! somehow, just having an airport card installed in the CPU affects the communications with ProControl, even if all the communications point to ethernet and NOT airport!
thanks for the tips though... : ) |
#16
That reminds me of the airport scene in the serpent and the rainbow.
Ooh! Wasn't that scary kids? I am shivering... ------------------ Angelo Quaglia AQ Productions
#17
Tweakhead
Appletalk control panel set to ethernet. On Mac OS 9.0.4 it is allways set to ethernet. Appletalk does not need to be on in the chooser. MJ Digidesign tech Support. |
Legacy User Nubie again Potential PC Build and New User | dj2big | Windows | 4 | 10-31-2012 09:52 PM |
AIR User Blog User Input | brianiac5150 | The Drum Room | 7 | 12-07-2010 12:23 PM |
New mac user - long time PC user. Need to install on Mac. | SixChurchStreet | Pro Tools M-Powered (Mac) | 0 | 04-21-2010 05:54 AM |
Tips for old PT user, new ProControl user please? | seanhupe | ProControl, Control|24, Command|8 | 11 | 04-04-2006 08:42 PM |
New Procontrol User | Chris Lambrechts | ProControl, Control|24, Command|8 | 2 | 12-05-2001 12:43 AM |
