Where are PT Plug ins 2023 on Mac?
PT 23.6.0.110
Seems like I have to look this up every year or so ..this time will write it down Thanks |
Re: Where are PT Plug ins 2023 on Mac?
/Library/Application Support/Avid/Audio/Plug-Ins
Macintosh HD/Library/Application Support/Avid/Audio/Plug-Ins
Or whatever your Boot drive is named instead of Macintosh HD I don't remember if Pro Tools installs the Alias in the Plug-ins folder for other plug-ins, but this is what my Plug-Ins folder looks like, which I keep in the Finder sidebar for easy access: Macintosh HD/Library/Audio/Plug-Ins Folder List: AAX (alias) AAX Unused (alias) Components HAL LV2 MAS Unused. (for AU) VST VST Unused VST3 VST3 Unused |
No luck nothing there...
Are you sure you are not looking in your "user name" Library? Click on your System drive icon and then on the Library there.
Easy mistake to make, I do it all the time. Or if you did not install Pro Tools for all users, maybe it actually is in your username Library. |
Clicked on Macintosh HD.
Held option clicked Library from the GO menu Application Support Avid Only shows Avid Link (twice) And Pro Tools/cache and Cookies. Geez, can't Avid just make a "Go To Plug Ins" menu command? LOL |
Without wishing to be rude, if you can't find these, perhaps you shouldn't be ferreting around in your OS folders.
Spotlight search won't show you these by default. Use a program like Find Any File to do a search for "aaxplugin". The path you've been given is correct. Macintosh HD/Library/Application Support/Avid/Audio/Plug-Ins Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
Yep, I was wrong about Spotlight finding it.
Did a find using Find Any File as Dominic suggested for AIRChorus.aaxplugin and it showed the correct path. |
And yes putting an ALIAS in the FINDER lol |
Forget spotlight and open Terminal app from Utilities. Issue this command:
Code:
find / -iname '*aaxplugin'
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta | theodd | Avid S1, S3, Dock and Control App | 14 | 10-19-2023 07:23 PM |
does 2023.9 work in os10.14.6 if i use the 2023 hd driver? | [email protected] | Pro Tools | 1 | 09-25-2023 09:13 AM |
Pro tools 2023.3 No Playcell plug in | Dor.Avitan | Pro Tools | 6 | 06-06-2023 05:56 AM |
Which plug ins are broken in PT 2023.3 and why?!? | Franklyn | Pro Tools | 23 | 03-31-2023 08:07 AM |
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! | off the wall | Pro Tools | 9 | 03-28-2023 10:33 AM |
