Old 06-28-2023, 11:06 AM
IntelDoc IntelDoc is offline
Default Plugin (Automation lane settings)
All,
It's been a long time since posting. Was wondering if I am overlooking a setting. I have noticed that my plugins are not saving automation settings when I am going in and selecting items that I want to automate. What I mean as an example is this.
SSL Channel Strip 2. I load up the plugin and then go to the automation section and select "Fader Level." I then save the setting as "Starter" and then make it load that up as a default for that plug. It loads up the "starter" preset, but the automation lane "Fader level" does not populate in on the plug. This would be super helpful to my workflow to NOT have to go and set that each time.
Is there a setting somewhere that I am missing to have this load.
Thanks for the help
MONUMENT SOUND
MONUMENT SOUND ON YOUTUBE
Monument Sound Facebook
"Changing how people hear music one track at a time"
Old 06-28-2023, 11:30 AM
Tweakhead Tweakhead is offline
Default Re: Plugin (Automation lane settings)
2 possible workarounds for you:
1. Create a Track Preset, and simply import the plugin assignment/settings/automation
2. Always have a dummy track in your session with that plugin & setting configured, and option+drag it to your desired tracks.
'Suspend Automation' enabled, resets all my plugin settings! GuitarGiddz macOS 8 08-24-2020 07:54 AM
Plugin automation working but lane doesn't exist basehead617 Pro Tools 2019 2 01-15-2020 12:34 PM
Is it possible to save automation just like a plugin settings P,B,S macOS 1 11-24-2012 06:36 PM
No Send Pan automation lane on 9.0.3? Craig F macOS 1 04-21-2012 12:12 PM
automation bug in bypass lane Postman Post - Surround - Video 8 01-04-2012 06:20 AM
