Old 02-19-2020, 12:49 PM
Steve@ZooWest Steve@ZooWest is offline
Default Strike Not Responding
I can open the Strike interface, but it is completely unresponsive to my mouse and keyboard. I can import Strike from another session, and the sounds from that session are available, but nothing can be changed as it is still impervious to mouse clicks. However, it does respond to playing from the keyboard in that case, with a strange twist - no patterns or fills can be triggered by briefly depressing a key - keys must be held down to continue playing the pattern or fill. And in the session, it's the same - midi notes must be the full length I wish the pattern to play; otherwise it stops.
I tried unsuccessfully to find where to re-download and re-install.
I have a new keyboard and mouse that seem to be working fine otherwise, so it seems unlikely that's the issue.
UPDATE: Trashing Prefs fixed the unresponsiveness issue, so I'm up and running. Still have the issue that I must keep keys depressed to continue patterns or fills playing, and same with MIDI note length in the sessions.
PT 12.4
Windows 10 Pro
64GB
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 02-19-2020, 01:28 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Strike Not Responding
Glad to hear you fixed the first issue. There's a LATCH button to the left of the keyboard - either hold a key (or draw out a note for the length of the desired part) with Latch off, or enable Latch. Does that help?
linkedin
HTML code is On
Air Strike GUI not responding crizdee AAX Plug-ins 10 04-07-2016 04:23 PM
Problem with Strike 1.5-Pro tools 10 wants to move Strike.dpm to unused folder. We live forever Virtual Instruments 55 09-17-2012 06:02 PM
Strike Not Responding mrgroovy macOS 5 01-13-2012 09:22 PM
Installed Strike, activated license with iLok> no Strike. seeeker Virtual Instruments 3 10-17-2010 04:21 PM
DAE error #7400 PC (STRIKE only)????? STRIKE WONT LOAD!! TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-21-2008 08:19 PM
