Old 03-01-2012, 02:33 PM
Codo Codo is offline
Default 32bit or 64bit??
Dear Forum.
Can I benefit from starting OSX 10.6.8 in 64bit mode when I run PT9 HD3? (Mac Pro 3.1, 2x4core 2.8GHz 16GB RAM)
As far as I know, MacOSX will allocate the same ~4GB for the 32bit PT9, but a nerdy friend of mine told me some stuff about "flushing the cache". He said it should be beneficial to run the OS in 64bit mode, when I was using this 32bit program...???... It should somehow work better. Anyone knows?
Often I run short of memory, when I have loaded a range of VI´s in larger arrangements along with a line of voices.
Is there any settings within PT9 which can prevent these crashes?
Of course I´m trying to be tactical in my use of VI´s. Sharing same machines with different MIDI-track numbers, loading least possible samples, using Kontakt memory server etc.
But does the number of voices etc. make a difference?
Does any other VI´s than Kontakt use external memory server?
Thanks for helping me out
Old 03-01-2012, 06:46 PM
[email protected] stvbn@yahoo.com is offline
Default Re: 32bit or 64bit??
Pt9 is a 32 bit application; your numbers are correct, 4 gig can be the largest session, but you will likely see issues around 2.5 gigs, 64 bit won't help.... open activity monitor and see how big your session is. VI's are a killer in ProTools when used in large numbers.
Running any number of VI's above 4-5 can create issues... ( i am running PT 10 and try to stay under 5, it is a little bette,r and will likely improve in PT11).... VE Pro is what most people use as a rewire app into PT when working with large numbers of VI"s. Otherwise print your VI's and continue...
-SteveB.
Old 03-02-2012, 01:41 AM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
In theory, the only reason to run the 64-bit kernel is if you have more then 32 GB RAM installed, because the 32-bit kernel can only access a maximum of 32 GB RAM. For example, the latest Mac Pro 5.1 Westmere with Dual CPU's can be loaded with 96 GB RAM (or even more).
However, if you run 64 bit applications for hosting your VI's (for example VE Pro) it is important to run the 64-bit kernel so VE Pro can access all of your RAM instead of the limited 4 GB for each application.
I did some testing with my system (see details below) and I found the 64-bit kernel being smoother and a little bit faster, even without more then 32 GB RAM
More info about the 64-bit kernel can be found here
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
Old 03-02-2012, 03:14 AM
JFreak's Avatar
JFreak JFreak is offline
Actually 32-bit kernel can only access 4GB RAM, but there are workarounds which is why Avid was able to pull the Disk Cache out of the hat...
Janne
Plugins for S3L, 32bit vs 64bit? Kristo Kotkas VENUE Live Sound Systems 9 09-27-2013 02:36 AM
Pro Tools 9 on 10.6.6 Snow Leopard: 32bit or 64Bit? David Ziegler macOS 5 06-07-2011 07:44 AM
32bit PTS plugins will it run on Win & 64bit? andre67 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-12-2010 07:41 AM
002R will it run 32bit 7.4 and 64bit 8.0.3 both? aka21stCentury General Discussion 3 06-12-2010 11:36 AM
going from 64bit to 32bit sterndrup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 12-11-2008 10:12 AM
