  #21
Old 04-21-2017, 10:12 AM
KPereira KPereira is offline
Default Re: free ADR cueing software
Thank you so much for not only making this software, but continuing to adapt it (for free!)
I just discovered it and am using it on a current project.
I do have a quick question. Is there currently an option to export either the Reason or the note field to a column in the excel version? If there is, I must be missing it.
Thanks again!!
  #22
Old 04-21-2017, 11:07 AM
Pete Gates Pete Gates is online now
The Excel was originally more for the music list use of the software rather than ADR. No, those fields aren't output. I can definitely look at outputting more of the ADR fields to Excel than it currently does.
Pete
  #23
Old 04-21-2017, 11:19 AM
Meads Meads is offline
You're giving EdiCue a run for its money, Pete. Keep it up, awesome work!
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
  #24
Old 04-21-2017, 12:47 PM
Makes sense.
Those are the two fields that would be useful relating to ADR. When reviewing cues, we add a new column to and excel each giving our notes. I then update the session manually.
Those fields (Reason Code, Notes) are the two I have been manually moving over or just re-typing the reason. Not so bad but w/ a ton of cues...
Such a cool tool
Originally Posted by Pete Gates View Post
Pete
  #25
Old 04-24-2017, 05:05 PM
Originally Posted by smurfyou View Post
One question and maybe I'm missing it - is there a way to print the Out TC as well?
Done.
Done, plus some - Notes / Flags / Reasons / Scenes / Priorities are put into the Excel now.
Pete
  #26
Old 04-25-2017, 08:21 AM
Done.
Also, export engine is now very multithreaded, exports complete a lot quicker on multicore machines.
Pete
This is great, thanks!!!!!
  #27
Old 04-25-2017, 12:12 PM
smurfyou smurfyou is offline
Pete, this is very generous of you. Thanks!
~Will
  #28
Old 04-26-2017, 02:27 PM
Been finding a lot of cues on the current show (and in general) have reasons of "Rustling" or "PFX."
Aside from manually entering as custom, what reason are y'all using for these? Clarity or noise? Then add a note for Rustling/PFX?
  #29
Old 04-26-2017, 03:10 PM
Rustling I could add, PFX though? Is that an ADR reason? Eventually I'll need to do a more user-extensible thing as otherwise the default list could get huge!
Pete
  #30
Old 04-26-2017, 06:41 PM
I just called it noise. On my old cue sheets I would specify rustle or hit or whatever but "Noise" works well enough
~Will
HTML code is On
From MAc to PC: ADR Cueing software and soundminer gsilbers Post - Surround - Video 5 11-10-2011 10:42 AM
Cueing Mac and Xp pro tools le 7! plz read DukeDiddy89 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-16-2011 12:46 PM
ADR - cueing-beeps... clusterer Post - Surround - Video 29 02-17-2006 05:52 AM
Cueing Headphone Mixes - how?? mixit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-20-2004 05:52 PM
Error Cueing DV Machine InnoForm Media Pro Tools TDM Systems (Mac) 6 05-09-2004 09:56 AM
