Loco for latency
Windows XP SP2|Pro Tools 7.3|Mbox2|Fantom S-88--I'm running a midi cable from the OUT of my Fantom S synth to the IN of my Mbox 2. I can record MIDI through Xpand (and while recording, everything sounds fine), but upon playback there are extra notes, skipped notes, and just an overall playback mess. I've done the recommended steps to increase processing speed. I've set the synth to slave-midi and MMC to slave, turned off local, etc. I'm pretty sure I've configured Pro Tools properly as well, but I guess not. Please, experts...I need you.
Re: Loco for latency
Crazy for latency? not in this thread.
OSX10.6.8, 1st gen Power Mac, PT8.0.5, Mbox2 |
This thread would appreciate an answer. Any takers?
Try this:
I would suggest turning off all that sync and MMC crap.. If you are triggering a VI in Protools and recording the MIDI there as well, then all you really need from the Fantom is for it to act as a controller. If you are using The Fantom as the sequencer and need PT to sync up, that's a different story. MIDI thru must be on Make a stereo Aux track. Insert Xpand Make a MIDI track. Leave it's input set to all and set it's output to "Xpand> channel 1" Record enable the track. You should now be able to play your keys, getting the meter moving on the MIDI track and the AUX. Now, start recording. What happens now when you playback?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Same story. I'm not sure I know how to turn off syncing capabilities from the synth. But from PT I unchecked "use MTC" and unchecked both MMC slave/master to midi. Midi through is certainly checked.
Automation latency when using plugins that have long latency | pyrodave | Pro Tools 11 | 2 | 01-27-2014 11:22 AM |
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Anyone still using Loco/Titan? Need to do some re-assembly | mondoJML | Post - Surround - Video | 4 | 04-21-2008 01:38 PM |
bloody hell! ADR es loco! | chagos | Post - Surround - Video | 13 | 11-18-2004 08:29 PM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
