Re: I can't drag and drop with Structure free.
Not sure which manual you are looking in, but this is where I would look:
Pro Tools 11 Documentation (All) AIR Creative Collection Guide Chapter 26: Structure Free Quote:
http://akmedia.digidesign.com/suppor...revC_39332.pdf I also just looked through the one you sent me but it's just about the same info, it tells me how to load patches but I don't believe that's the same thing and to even make a patch of your own, guess what, you need to drag and drop lol.
Intel i7-4770k, AMD Radeon HD 7870, 8gb G.skill 1600mhz, MSI G45-Z87 Gaming, Samsung Evo 840 120gb, 3tb Toshiba, Corsair CX750M, Fractal Design R4, Win 7 Ultimate 64bit & OSX Yosemite, Asus 27" MX279H |
Some of the things in this new blog post may help:
Sticky: Using the Free Pro Tools 11 Virtual Instruments Also, this one may be useful: Structure Free - Pro Tools Tutorial It starts by editing existing existing structure patches, and around the 13 minute mark it goes into creating patches from audio files/samples. |
Its really not that difficult. Once you have an audio clip (usually WAV) of a source sound you want to import to Structure, all you need to do is go into Structure free and import the sound there in the sound field on the left side of the Structure screen. To simplify matters, keep your source samples in an easy to find file so you can navigate to them easily. Once imported, you can assign them to which key you wish to trigger the sample(s).
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Intel 6 Core i7-4930K CPU @ 3.40GHz 32GB DIMM DDR3 G.Skill Samsung SSD 840 EVO WD Black SATA 7200 ASUS SABERTOOTH X79 Windows 7 Ultimate 64 Mbox3 Pro Firewire 400 ProTools 10.3.8 ProTools 11.3.1 https://soundcloud.com/matthewcrowe |
I can't comment on the operation of Structure free but in the full version the drag and drop situation goes like this:
In all Structure 1 (RTAS) versions you can drag and drop from pretty much anywhere. In Structure 2 (AAX) versions you can no longer drag and drop from within Pro Tools itself, either the region list or the edit window. But you can still drag drop direct from the finder (and presumably explorer). It was my understanding from discussion in a previous thread that this was something to do with the AAX code itself but I don't really know. Having said that I'm still finding Structure buggy as hell, the new version even more so than the old one. So an alternative sampler might be the better option if you value your sanity |
I read somewhere, I'm sorry I can't remember where, that dragging from the timeline/folders into Structure was more of a bug than a feature. It was never suppose to be able to do that, but through a hack, the developers found a hook that allowed it. AAX plugin APIs closed that option.
try printing a wav file from Pro Tools then dragging that into Structure Free.
It would be nice, because you could chop up the sampple in pro tools edit view, and then drag it into structure, but now you can't. I haven't figured out a way to use it yet, besides working with kotnakt
A workaround would be to slice up your sample in the region view, cut and paste each slice to it's own individual track, mute all other unrelated tracks, then bounce the tracks out. Once bounced, you can grab them all at once from your OS and drag them into Structure to create a patch.
Structure: No Drag and Drop?? gone in aax | Rectifried | AAX Plug-ins | 10 | 11-08-2013 10:56 AM |
Structure - next patch or only drag/drop? | andrewpiano | Virtual Instruments | 5 | 05-18-2010 07:14 PM |
Bug in Structure free drag and drop | BR Rundfunk | Virtual Instruments | 0 | 02-10-2009 07:26 AM |
Structure Drag n Drop stereo from PT | arild | Virtual Instruments | 0 | 09-25-2007 08:21 AM |
Structure drag n drop | pindebraende | Virtual Instruments | 58 | 09-16-2007 03:46 AM |
