monitor inputs to headphones
Hello
When I start a project, I want a metronome on my ear.I use my outboard sound module for the metronome sound. This module is connected to input 3/4. But I can't find a way of routing them to the headphones. I can listen via arming an audiotrack, but then I record a audio clicktrack. I don't want to do that. I hoped to avoid a mixer, is there a way around this? If there isn't, I will suggest that Digi upgrades the 001 so that input 3/4 is routed to the phones as well, when the monitor switch is pressed. regards Jan |
Re: monitor inputs to headphones
You will need to create an Aux Track within Pro Tools and set its inputs to 3&4 (i.e. same as where your sound module outputs are connected).
This will give you the ability to monitor the outputs of your synth without recording the audio. Brent |
Monitor Headphones | Alvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-27-2002 12:25 AM |
best monitor headphones for under $300 | agent fu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-21-2002 10:26 PM |
Best monitor headphones for under $300 | agent fu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-21-2002 10:06 AM |
Monitor Latency and monitor thru headphones output... | jeronimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-06-2001 08:30 PM |
Monitor Modes and Headphones | JKD99 | ProControl, Control|24, Command|8 | 4 | 03-16-2000 03:18 PM |
