A Super Thorough Project Archive Procedure
I've been working on a procedure to prepare a project for permanent archival. This is intended to be as thorough and "future-proof" as possible and takes just about every situation into account.
It archives the following:
Section 1 - Initial Preparation 1. Click File > Save copy in to copy the project into an archive location. This should probably be a different folder from the original project. Section 2 - Wet, 32-bit, Float This format is used, internally, by the Pro Tools audio engine. It should be preferred for mixing or stem mastering if the DAW supports it. 1. Add all of the tracks that you want to commit to a group.Section 3 - Wet, 24-bit This format is primarily used for long-term archival purposes. It can also be used for mixing or stem mastering. 1. Duplicate all of the "Wet.32bitFL” tracks. From the Duplicate dialog box, ensure only “Active Playlists” is selected. Section 4 - Dry, 24-bit The format contains an easy-to-use archive of the original performance, sans effects. It can be used for remixing projects, where the original, dry, tracks are preferred. 1. Disable all inserts for audio tracks. Only leave the basic instrument inserts enabled for MIDI/instrument tracks (basically, disable all effects).Section 5 - MIDI 1. For each MIDI track, right-click on the track and select Export MIDI. Don’t use File > Export > MIDI. This will export all tracks for the entire session (unless you want that). Section 6 - Bounce 1. Add a limiter to the Master fader with -0.1 dB of ceiling (or whatever you like). Don’t reduce the headroom or do anything beyond basic peak limiting. Section 7 - Unused File Removal Don’t do this unless you are certain that you want to delete any alternate takes and unused clips. This will affect all sessions that are using these files.
Section 8 - Clean-up This section should make it easier for someone (possibly you) who opens the project up years in the future. They will see the entire project and be able to just start playing it without having to figure out which tracks are active and without having to sort through plugin issues.
Section 9 - Session info 1. Go to File > Export > Session Info as Text. Session 10 - Test 1. After everything is done, close the session and re-open it. Ensure that it is not complaining about missing anythingWhat do you think? |
Re: A Super Thorough Project Archive Procedure
Wow - cool, but it looks like a lot of work. I just copy my session folder (including bounces) to 2 ext hard drives and call it a day.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
I found a relevant article from SoundOnSound about the 32-bit FL vs 24-bit archiving formats. Their position is that you should always keep a 24-bit version around, as this is the most universally accepted format.
https://www.soundonsound.com/sound-a...nt-audio-files |
I just archive my old computers and build a new one about every 5 years or when major changes happen such as 32Bit>64Bit to 'futureproof' being able to use old formats.
Other than that I'm with EGS.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
2) save session copy in .. 24bit would this work ?? i am all about simple !!! yours is truly thorough !!!
As far as I can tell, those save session copies just make a copy of your project, without committing anything.
I guess I could commit everything and then do a "save session copy" to 24bit, but that creates a whole separate project folder, right? It seems easier just to duplicate all of the committed tracks, which are at 32-bit FL, set the Rendered Bit Depth to "follow session settings," and re-consolidate them, which instantly converts them to 24-bit. The trickiest part is getting all of the dry commits. That's for the hardcore archivists, and probably more for composers than full-time post guys. For archival, I prefer to have each track, including MIDI instruments and effect aux tracks committed to audio, from the very beginning of the session all the way to a bit past the end. I don't entirely trust that those "broadcast wave" timecodes will work in every DAW, including into the distant future. I had a nightmare in the past where WAVs didn't have the timecodes, or the DAW was unable to read them and ended up with a jumbled mess. If you start everything from Beat 0, you don't have to worry about them not lining up in some other DAW. In fact, this procedure is probably a symptom of post-traumatic stress. I'm like those old people who grew up during the great depression and never trusted banks after that, so they stuffed money in their couches and mattresses instead of using a checking account. |
I Remove unused files FIRST (Remove, not Delete) and THEN do the Save Copy In.
This avoids the time and space it takes to copy unused files that you're only about to delete in the next step anyway. If you close the original sessions without saving, it's still intact there.
William Wittman Producer/Engineer (Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!) |
but if you have already created them for Delivery then no they would not be automatically added .. we have to do some work, and we have to have some billable hours .. right !!!
Archive and Install | cjac9 | Pro Tools M-Powered (Mac) | 0 | 06-19-2006 11:02 PM |
Archive & Install - Archive & Erase | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-26-2005 12:14 PM |
archive sessions to DVD | bluemt | Pro Tools TDM Systems (Mac) | 3 | 03-07-2003 01:31 PM |
archive in PTLE | gmo | Pro Tools TDM Systems (Mac) | 1 | 10-21-2002 12:14 AM |
Ultimate Archive? | rpalagy | Storage Subsystems | 0 | 01-18-2002 12:37 AM |
