Eucon personality issue
Hi everybody. First of all sorry for my english, i'm italian. Well, the problem is simple. When I try to enable the EUCON button in "PT 10 Educational" it gives me an error saying: "Error occurred while trying to load the controller personality "EUCON".
I have: Windows 7 64bit and I would like to use my Mc Mix Does anyone know why? |
Re: Eucon personality issue
Check my previous posts. I had the same problem. You have to set the ip4 address to a fixed number and then you have to install the software after.
Found it after a bit of digging...
DO THIS, THEN INSTALL THE SOFTWARE.... http://avid.force.com/pkb/articles/e...p;DocType=1080 I am using a network switch with my PC and my Mc Control plugged into the ports on the switch. I have internet access with the switch as well. The only reason I am using a switch instead of a router is I have a second WIFI network in my studio. So this will work with either a router or a switch. |
Actually just try to set the ip address and reboot and see if it works...
I set my firewall to medium protection and now windows see the Mix but, when I open PT and I try to enable the EUCON button it gives always the same messagge So what is the problem now? What do I have to do
I would reinstall the software and reboot. Are you going through a router?
Thanks to all but I solved. I set different ip and now everything works. However, I have already decided to dedicate this pc, previously configured for the game, for music only and buy a laptop for everything else.
How did you get it to work? Im having the same issue. How did you change the iP address I tried it but it still didn't work. What was your process?
HP Pavilion p6620f PC Windows 7 Home Premium 64-bit AMD Phenom II 820 Quad-Core Processor 8GB DDR3 system memory 1TB hardrive memory ATI Radeon HD 4200 intergrated graphics Pro Tools 9, FL Studio 11 Producer Edition Mbox pro 3rd Gen, Mbox mini 3rd gen M-Audio Axiom Pro 49, Novation mini nova, M-Audio AV 40 Monitors, M-Audio BX8a monitors, M-Audio NOVA Condenser MIC, AKG Perception 220 Microphone, Rode NT2a, Avid Artist Mix, Avid Artist Control, NI Maschine, Glyph GPT50 3tb |
"EUCON Personality could not be loaded" Error? | Convectuoso | Artist Series | 17 | 10-12-2023 08:12 AM |
controller personality "EUCON" incompatible | Pz5 | Artist Series | 8 | 06-04-2013 11:39 AM |
Cannot load Eucon personality | ianmiller | Artist Series | 11 | 02-13-2013 02:32 PM |
HELP!!! Eucon personality issue | ballando | Pro Tools 10 | 0 | 10-13-2012 02:16 AM |
Control 24 Personality issue | youngas75 | ICON & C|24 | 0 | 12-02-2008 10:50 AM |
