Volume Automation - Delay when writing touch/trim
Hey guys
I'm automating some vocals using a D-Command with Pro Tools 7.3.1 I've got the track in the edit window showing volume graph. When I touch the fader and start making volume moves, I see the yellow trim graph line moving right with me.....but when I stop playback and pro tools coaleses my moves they are all delayed by a fraction! As the yellow trim fader graph line with my intricate moves gets coalesed and turns into the black volume graph line, I literally see it all move on screen! How can I get pro tools to keep the original trim move that I made and not apply any kind of delay before writing? Why is it doing this? Thanks!! |
Re: Volume Automation - Delay when writing touch/trim
For what it's worth; I'm not seeing that here. The automation is not moving when I stop, and it's the same if I coalesce manually, after every pass or on exit. What I did notice, however, is a slight flickering of the waveform when I touched the fader, but that's probably for another thread.
Here's a quick video to demonstrate. You can literally see the automation move to the right after it's written. I made the steepest part of the move before the grid line but then it's written after the grid line! How can I stop this happening and make Pro-Tools write the automation exactly as it initially sees it? (ie the red line)
http://www.youtube.com/watch?v=HfTN-60QtyM |
Not sure if it's the same thing, but here's a thread I started describing something very similar:
http://duc.digidesign.com/showthread.php?t=278033 FWIW, Digi participated in the thread for a while and said they were looking into it. Nothing came of it though.
Mark |
Cheers, hopefully the issue can be solved. |
Writing Automation on Volume Trim... Possible? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 9 | 02-25-2012 10:53 AM |
how to zero out volume trim automation | univox1 | Tips & Tricks | 1 | 09-08-2010 03:19 PM |
Deleting automation accidentally w/ touch trim? | jahtao | Post - Surround - Video | 2 | 06-03-2009 08:56 AM |
Automation over writing problems in touch latch using a d-co | Brandonx1 | Post - Surround - Video | 0 | 04-15-2007 11:16 AM |
Delay Compensation and Touch Mode Automation | Barnaby Bristol | Pro Tools TDM Systems (Mac) | 0 | 10-18-2005 02:50 PM |
