"Could Not Allocate Space For Recording"
All,
Has anyone has this pop up, and what causes it? I had started a new session, tried to record and I got that message. Not having much time to troubleshoot, I just started a new project and everything worked as expected... Just curious what caused that? Thanks, Mark
Mac Mini, 32 gig Ram, OS X 10.14.4 - Mojave, Scarlett, PT 2019.6 |
Re: "Could Not Allocate Space For Recording"
I'm just bumping this as I still can't figure it out?
Digi, any ideas? Thanks! Mark
If it's not a problem anymore, I wouldn't worry about it.
Just a quick question but, are you low on HD space? (had to ask.) |
Hey, we had this happen on Saturday also. Very strange. Created a new session and we were ok but it had our heads down for a while. Our drives have loads of space available. 'Could not allocate space for recording' -- what's this all about?
Cheers.
Simon Allen City Studios Cyprus |
Also, the drive had PLENTY of room.... So, let's see what answers we can get... Thanks all, Mark
What types of drives are you using? Did you try it with a different drive? Did you get the same result? Is this happening in only one session or all sessions? What's your Open Ended Record Allocation set to - all available space or limited to a number of minutes?
It may have been a corrupted session or a glitch of some sort. Having open ended record allocation set to all available space can sometimes cause this as well. |
Thanks for the reply. I'm using drives that have worked for sometime with no issues, and it only happened so far in one session. I do have it set to open ended recording, so maybe that's it... Thanks, Mark
One possible reason for this is that the Audio Files folder may be inadvertently set to "Read Only." Select the folder, then type Apple I to bring up Info. Click on the padlock at the bottom, enter your OS password, then change the drive to "Read and Write."
Can SOMEONE PLZ HELP ME I HAVE A OLD PROTOOLS 7.3 le on a Mac (ibook g4) and I was recording a song came back the next day and I tried to record and it says "couldn't allocate space" I deleted some files and it continue to say that...I tried " verify and repair" my disk that didn't work and my computer says it has 272 mb free space and 36.9 gb used (hopefully that info helps) please help me I need to record ASAP !!!!
How much free space do you have on your recording drive? Can you post your full system details:http://duc.avid.com/showthread.php?t=336556
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
PT 10HD Native - "Could not allocate space for recording" | jseelye02 | macOS | 1 | 02-11-2014 10:45 AM |
"Could Not Allocate Space For Recording!" Error Message | TheEvilCow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 06-18-2011 01:34 PM |
ERROR MESSAGE : "Could not allocate space for recording! " when recording audio. | Save|The|Architect | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-03-2011 10:04 AM |
Dialog box reads: "Could not allocate space for recording" | stringplayer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-25-2010 10:39 AM |
"unable to allocate disk space for recording" error | guslov | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-01-2002 08:15 AM |
