Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 07-17-2018, 10:45 PM
LukeHoward LukeHoward is offline
Default Weird MIDI import/export issue
I'm on Pro Tools Ultimate 2018.4.0 on HDX.
I'm attempting to export a 48k session into a new 96k session, either using Save Copy In (from source session) or Import Session Data (from the target session). Instrument track clips are showing absent any MIDI data unless I uncheck the "Apply SRC" option (which, of course, should be irrelevant).
(To be clear: the clips are there and in the right places on the timeline, but there is no MIDI data in them. I haven't tried with pure MIDI tracks.)
Am I the only person to have experienced this?
I've worked around it by importing the audio tracks (with SRC) and instrument tracks (without "SRC") separately, but this seems a very unusual bug.
Old 07-17-2018, 10:49 PM
Default Re: Weird MIDI import/export issue
Actually, it's worse than that: when importing instrument tracks without "SRC", they're showing up at the wrong spot on the timeline – I suppose this makes sense if absolute sample values are retained (all instrument tracks are sample- rather than tick-relative; obviously, that's the next thing to try).
EDIT: OK, it works if the source session's Instrument tracks are tick- rather than sample-relative. So that's a workaround.
PT 11.1 weird file import issue paulo m Pro Tools 11 0 01-07-2014 05:19 AM
Import/Export Midi jwilkers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-22-2010 10:52 AM
PRO TOOLS EXPORT TO CUBASE IMPORT TIMING ISSUE Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 07-25-2007 05:22 AM
Weird error message on MIDI import Ray Lyon Pro Tools TDM Systems (Mac) 13 08-18-2005 08:20 AM
Import/export Midi files- Where are they? JPS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-25-2001 08:19 PM
