Mbox Pro not available in the Pro Tools i/o choices
Hi All,
I have a new Mbox Pro and Pro Tool 10 LE system. I can not get the Mbox to show up in the I/O choices. In short I can't record to pro tools through the Mbox. The mbox is in my Playback Engine set up. The Mbox is the I/O set up section. The Mbox is the input and output in Sound of my Preferences. I really hope someone can help me sync up my Mbox Pro as I have a full day to record tomorrow and I am anxious to try this new system out. . . Help. Thank you, Tom |
Re: Mbox Pro not available in the Pro Tools i/o choices
Try this: In I/O setup select all ins and outs (Command+A), delete them by pressing Delete, then default all by pressing Default. This basically matches your ins and outs to your current interface.
Vovique,
Thanks for your reply. Command +A is a nice trick reverted everthing to default. But no luck on mbox in the i/o or anything that will allow the mbox to send a signal to pro tools. I may be destined for a quick call into Avid Phone support on monday. thanks again, Tom |
Do you have the latest driver installed? 1.0.14
http://avid.custkb.com/avid/app/self...p?DocId=375655 |
IF drivers are installed press N on the keyboard hold it down as you open protools until pop up can you select your mbox ?
PTX should automatically recognize your mbox but you may need to do it manually in audio midi set up window ? |
Drum recording: 3 room choices, 3 channels, 4 mic choices - pls lend your advice!! | edgarbc1 | Tips & Tricks | 4 | 12-03-2009 08:40 AM |
Pro Tools HD2 PCIe - LGA775 motherboard choices | SHRED | Pro Tools TDM Systems (Win) | 0 | 11-22-2009 05:31 PM |
Choices!! | GORILLA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-04-2004 09:59 AM |
FW DVD choices | Bender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-18-2004 08:31 PM |
analog choices w/ Mbox? | phunk1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-25-2002 10:47 AM |
