Mbox 3 mini Voice issues
Hello !
i bought m box 3 mini some days ago, i installed it, however when i play music it has some noise (not pink) like distortion. I tried everything for it , i changed USB and installed new power supply with technician but no result Can you give me any suggestion ? Thanks ! George Last edited by GEORGEBAKHTADZE; 05-28-2015 at 02:19 PM. Reason: Voice issues |
Help us Help You - READ THIS Before Posting!
Find this link near the top of this(and every DUC) page. Its tough to offer any advice with almost no information about your system
In the link Albee posted, it asks for a full Sandra report. We need more information from you to help diagnose the problem.
First thing to try is the Optimization Guide, once we have more information we might be able to give more insightful advice. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Okay. first my windows has already been updated all drivers and all software.
MY PC IS: Intel Core I3 3.2GHz, RAM 8GB PS . I'm not Pro tools user, My DAW is Ableton live 9 About my problem : First of all i installed my driver which is downloaded from AVID official site then i restarted it and connected my M box mini 3 into the USB port , it was seen but when i played music it has some noise like distortion, then reinstalled my driver again but the result was not. I dont know what should i do, by the way i was M audio fast track pro user and i thought that i would buy better , but today my m box mini 3 looks like a trash. PLS help me AVID Thanks George You can see everything about my pc CLICK ON PICTURE Last edited by GEORGEBAKHTADZE; 05-30-2015 at 01:54 PM. |
SiSoftware Sandra
ID Host Name : George-PC Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS P7H55-M LX Serial Number : MF70AAG******** BIOS : AMI (OEM) 0303 07/15/2010 Total Memory : 7.9GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i3 CPU 550 @ 3.20GHz (2C 4T 3.2GHz, 2.13GHz IMC, 2x 256kB L2, 4MB L3) Socket/Slot : FC LGA1156 Chipset Memory Controller : ASUS Core (Arrandale) DRAM Controller 2x 2.93GHz (5.85GHz), 2x 4GB DIMM DDR3 1.33GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : G.Skill F3-10666CL9-4GBRL 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : G.Skill F3-10666CL9-4GBRL 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : FUS L20T-1 ECO (1600x1200, 19.9") Video Adapter : Intel(R) HD Graphics (12SP SM4.0 733MHz, 66MB DDR3 1.33GHz 128-bit, Integrated Graphics) Graphics Processor Storage Devices Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:) (D:) (E:) TOSHIBA MQ01ABD100 (1TB, USB2/SATA300, 2.5", 5400rpm, 8MB Cache) : 932GB (H:) TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) DiscSoftVirtual (4.2GB, ) : 4GB Logical Storage Devices Hard Disk (C:) : 146GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) TOSHIBA EXT (H:) : 931GB (NTFS) @ TOSHIBA MQ01ABD100 (1TB, USB2/SATA300, 2.5", 5400rpm, 8MB Cache) Hard Disk (D:) : 98GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Hard Disk (E:) : 222GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-S223C (SATA150, DVD+-RW, CD-RW, 2MB Cache) reFX NEXUS 2 : 4GB (CDFS) Peripherals LPC Hub Controller 1 : ASUS H55 LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : ASUS P55/PM55/3400 High Definition Audio Audio Codec : VIA VT1708S HD Audio Serial Port(s) : 1 Disk Controller : ASUS P55/PM55/3400 4 port SATA IDE Controller Disk Controller : ASUS P55/PM55/3400 2 port SATA IDE Controller USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.9 |
Thanks for the Sandra report.
Have you gone through the Optimization Guide I linked you to? What do you have your buffer set to? Try increasing your buffer setting, and/or removing some plugins to lower the CPU load. An i3 is not ideal, but you should still be able to get it going. Also, integrated graphics aren't going to help. Be sure you're not recording to the H:, 5400rpm drives cant keep up with audio recording. Joel
Thanks for your reply Joe
I did optimization, also increased buffersize then my pc was restarted. i tried and installed my audio interface on two different compiuter last day, but i had same problem . DAW is next steb , my first problem is that i can not listen music well it still has distortion effect , I tried everything but no result. |
I've heard some people sad that may i need USB hub, but i dont know it will work or not, i'm feeling embarrassed becouse i did not have same problem with my last audio card.
Try setting Windows to use the onboard sound card as its default audio device, leaving the Mbox to handle only your DAW audio. In general, Avid interfaces work well with Pro Tools, but they are not so great with other DAW programs
Mbox Mini w/PT10 OR Mbox w/Express | adrianbnd | Pro Tools 10 | 7 | 10-02-2012 04:01 AM |
Downgrading MBOX 2 to MBOX mini (Quick question) | Mista808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2011 08:29 PM |
Am I Missing Something?! Mbox Mini, Mac Mini, Shockingly Bad | gunark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-07-2010 12:58 PM |
Mac Mini and Mbox 2 Mini Issues | neilwilsonvoiceovers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-17-2010 09:34 AM |
Quality Dropoff from Digi 003 to Mbox or Mbox 2 Mini? | Steve7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-02-2008 02:10 PM |
