Bypassing Amp/Effects for mic preamp only
I am having trouble using the ElevenRack as a interface/preamp only for tracking vocals. No matter what I do the guitar effect is still there.
I did change the input to "mic" under the edit menu. Avid makes you pay for tech support via phone and sweetwater had me on hold too long. Hopefully someone has an answer here. Thanks in advance. |
Re: Bypassing Amp/Effects for mic preamp only
Are you running the mic through the Rig? What is Rig Input set to?
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Tried them all!
Set to "mic" right now |
You do not need to send the Mic through the rig if you are using a DAW.
All you need to do is choose MIC for the MONO AUDIO track input. You can send the mic through the rig if you want and use the effects in the Eleven Rack to shape your sound. If you do not want any effects, just bypass everything or switch the Eleven Rack to the Tuner. If you do not have MIC as an option for an input, then your IO is probably screwed up. Default it, and try again. Default the I/O in Pro Tools https://www.youtube.com/watch?v=rxZ9SgQm8H4
I ended up "resetting" my I/O to default and soved the issue. However, I get the error message everyime I start up Protools
Delete the Hardware insert on the track/s (reinsert if needed using current I/O configuration). After saving session, providing you do have a working platform (ie have enough system resources), next time you open it you shouldn't get the error message.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Tube Preamp (ADA MP-1) in 11R Effects Loop | oldjohn | Eleven Rack | 3 | 12-13-2011 08:14 PM |
Using outboard Preamp/Bypassing Mbox2 Preamp | KennyC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-10-2007 12:00 PM |
Bypassing Mbox 2 PreAmp | SoundtrackArcade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-14-2006 05:41 AM |
Bypassing Line Amp with a mic preamp | techdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-09-2004 12:08 PM |
Bypassing Line amp with a Mic Preamp? | techdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-09-2004 11:22 AM |
