C24 Home Studio Table Furniture
Could anyone recommend a good table to mount the C24 on in a small home studio ? Approx 1.5 - 2 metres wide, and deep enough for C24 and monitors on a raised section above it, and at the right height to work comfortably with the C24. I will only be using 1 or 2 racks (Digi 003 rack as an interface, plus perhaps one other), which doesn't need mounting on the bench. I envisage it would have a raised section at the back that the C24 could slip under, to put monitors and screen on. Most benches however seem to have these raised sections for mounting more racks. I have seen the Argosy ones and wonder if you know of others that would fit nicely ? Many thanks for your help. |
Re: C24 Home Studio Table Furniture
There are usually some used desks floating around at a fair price(new are really expensive) but all suffer the same flaw in my book(actually, 2 flaws):
#1-they all lay the console nearly flat, which makes it very hard to read/see anything without standing up and leaning over the surface. #2-they usually have a great big bulky and thick front edge, which forces the keyboard and mouse to either be very low(usually on a pull-out shelf) or up on top of the arm rest. If it were me(and I do like the c24), I would build something that addresses my 2 issues If you are not the cabinet maker that I am, consider; start with a pair of racks, 12-14 spaces on wheels, spaced about 30" apart. Add a flat top(plywood or MDF, painted black) and glue some strips of nice wood around the edges for looks. Place the console in the center and block up the back until you can read things while seated and push the C24 back until you have enough tabletop to fit keyboard and mouse. Then add a "bridge" across the back, just above the C24 meter bridge. Make that shelf 10-12" deep so it can support speakers and screens. At that distance, a 32-40" LED TV(1080P) would make a nice EDIT screen the space under the shelf on each side (if not wide enough for rack gear)would be handy for external hard drives and other small stuff that we always seem to need nearby.
So right, I don't know why this isn't addressed more. The DCommand is naturally raised toward the back But the C24 is way too flat to see the top knobs of the surface. So the answer is build one to suit your needs, more detailed yes, but if you plan on keeping the C24 long term then it will make your PT experience much more enjoyable
My C24 sits flat on an Anthrocart - no issues seeing what I need to see.
I'd strongly recommend against audio monitors on an overbridge - they'll sound much better if put on regular speaker stands a bit further away from you. Can't know without knowing the space, but monitors on desktop tend to have loads of problems in the lower mids in addition to being much closer to you then the average listener's placement.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Hi guys,
Thanks all for the great advice. I've only just bought my C24, which I'm totally loving, but haven't yet bought a desk for it so have generally been standing up while playing with it on a temporary desk of the wrong height. I think it's great advice to raise it at the back if necessary, I can see how seeing the LCD display could be quite tricky if you were not at a good angle. I will certainly go more down the DIY fully adjustable route than forking out for custom made furniture. And it is a great shame that this item isn't addressed more; what could be more important after investing in this gear than getting it set up in a comfortable position ? Cheers guys, |
Hi Rich Breen,
Could you let me know which Anthrocart product you use ? And thanks also for the advice about monitor position and using stands rather than an overbridge. Greatly appreciated and thanks. |
Well, since you're in London, check out AKA Design in London and their fantastic ProWave center section for C|24. Just scroll down the page. Here's the link:
http://www.akadesign.co.uk/prowave.html It's a lot less bulky and weighty than the Argosy desks. I'm sure glad I found them at the time I got my C|24. |
Wow, thanks a lot Sound Bites. AKA look fantastic, love the way you can configure your own configuration too, exactly what I need! Very glad you pointed me at them.
Many Thanks ! |
I don't know if this is any help, but this is what I use.
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM Mac OS 10.14.5 ProTools Ultimate 2021.6 HD Native PCIe Apogee Symphony I/O Avid HD I/O 192 I/O Waves DLI Apogee Mini Me Mbox Micro |
We use AKA and have two of their awesome desks and 6 rack units and some extra goodies for PUSH2 and Roli Seaboard. High quality and super sturdy! Looks very very expensive aswell and IMHO should cost more considering what an Argosy desk cost. These looks even better again IMHO of course
Middle Atlantic Studio Desk and Table | kdubyou | Buy & Sell | 0 | 08-11-2016 09:26 AM |
OT: studio furniture | philper | Post - Surround - Video | 1 | 11-12-2006 05:40 PM |
Studio RTA Furniture | gracejames | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 05-11-2004 11:35 AM |
OT: Studio Furniture? | magicpiane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-04-2004 12:48 PM |
studio furniture | dawner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-30-2004 08:15 AM |
