Old 10-18-2012, 08:24 AM
Cryos's Avatar
Cryos Cryos is offline
Default 10.3.2 Heal separation not working. [SOLVED]
Heal Separation is greyed out. Normally when you select across a separation you can heal it quite easily with Command H, now all I see is a greyed out command and can't heal a thing. Is this a bug?
Anyone else chime in please.
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 10-18-2012, 08:33 AM
Cryos's Avatar
Smile Re: 10.3.2 Heal separation works, sorry its me!
I was selecting across an audiosuite edit and the original file, of course it ain't gonna heal! The problem is usually 24 inches away from the screen.
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 10-18-2012, 09:52 AM
Default Re: 10.3.2 Heal separation works, sorry its me!
How about using consolidate instead?
Old 10-18-2012, 03:26 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Talking Re: 10.3.2 Heal separation not working. BUG?
I like to use the technical term "PEBKAC"
Problem exists between keyboard and chair
Of course when that happens, everything becomes FUBAR
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 10-18-2012, 03:52 PM
Default Re: 10.3.2 Heal separation not working. BUG?
I attribute it to the nut that holds the keyboard
Old 10-18-2012, 07:44 PM
Cryos's Avatar
Smile Re: 10.3.2 Heal separation not working. BUG?
I love it! PEBKAC, never heard that one before. I'll keep that as part of my regular vernacular. You made my day bro!
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 12-23-2012, 12:46 PM
FERGY FERGY is offline
Hi all.
I'm sorry but I don't get this. You mean 'heal separation' can only be used on unedited raw imports/recordings? I'm trying to join two parts together but nothing seems to work! I can't get rid of the silence and sync them up. Any help would be much appreciated.
Old 12-23-2012, 01:47 PM
Craig F Craig F is offline
Heal really only a fancy undo, it can not join AS modified or different parts
Consolidate will join anything into a new file
Thank you,
Craig
Old 12-23-2012, 02:35 PM
Thanks Craig. When I consolidate the two regions, the silence in between is still there. Is that usually what happens? I edited (fade in/out) both the regions before trying to put them together.
Old 12-23-2012, 03:11 PM
silence is silence
if the timing of the pieces is correct you probably want some reverb to fill the void
if the timing is not correct you need to move the parts so the timing is correct
Thank you,
Craig
Pro Tools 10.3.3 not working with MAC 10.7.5 [solved] tchambeau Pro Tools 10 9 02-13-2013 02:17 PM
Heal Separation gone? Reckless Erik Pro Tools TDM Systems (Mac) 5 12-17-2009 06:33 AM
Low Latency Not Working! Has Anyone Solved This?? orangepopsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-24-2007 11:56 PM
Heal Separation process question Paul Alvarez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-16-2006 04:40 AM
Digi wont consolidate or heal separation surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-28-2001 02:34 PM
