Old 12-01-2003, 06:29 AM
wonderfall wonderfall is offline
Default Convert midi files to audio with Gigasampler sound
Hi all.
I have MBox and Tascam US-122 usb soundcards.
It is impossible to have them both connected (usb overloaded), so whether I use ProTools or Gigasampler at a time.
I'd like to use the sounds I have with gigasampler with the midi I program within PT. I thought I should record this midi to audio outside of ProTools and then import the wav back to my PT session. So what I do is : export Midi from ProTools.
Then I open it with Cubasis (shipped with Giga and US-122) that I set up to playback through Gigasampler. No Problem. But then, I cannot record that to an audio file!!!!!! (found no way to do it at least...
So my question : how should I do ??
I thought that using PT free might be the solution (hardware independant so I could use it with the US122 with Gigasampler) BUT it does not run on winXP...
Any other Idea?
Thank you!!
TravelMate (2.5GHz, 1GB RAM)WinXP,PTLE 6.1.1, MBox, SP C1, Edirol PCR-30, Johnson J-Station DrumOnCans
Old 12-02-2003, 04:23 AM
Default Re: Convert midi files to audio with Gigasampler sound
No luck with this forum...
Is it that nobody has a clue?
Am I not understandable?...
Help needed!
Thanks.....
Old 12-02-2003, 06:02 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
This may help if you haven't read it. Cubasis for Tascam - Apllication Notes
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 12-03-2003, 05:32 AM
Thanks Cliffy-Boy.
I actually hadn't read that...
But my set-up is already ok for playback! I sequence from Cubasis and use Gigastudio24 as a synth.
The problem is : HOW TO RECORD the output of Giga ?
I'm surfing the net and it seems to be a standard question... no standard answer for the US122 though...
Thanks.
Old 12-03-2003, 07:07 AM
Cliffy_Boy's Avatar
I don't know much about cubasis - it's recording capabilities. I did this with Cubase Sx and Logic - It may be a routing issue. If you take the output thru a small mixer and route the outs to your audio interface, could you not press rec on cubasis? The midi will trigger giga whose audio will come back into to a cubasis audio track.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 12-03-2003, 08:09 AM
Yes that's exactly what I want to do, but no success...
I get an empty wav file (while I can hear the midi played)...
Well I directly sent a question to Tascam... may take long, but they are in the best position to answer...
Thank you anyway!
Cheers.
C.
Old 12-03-2003, 10:11 AM
Cliffy_Boy's Avatar
try recording at a lower bit rate. If Tube is on, turn it off. ( May only be available in SX)
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Importing audio files for remix - convert or set session to match source audio? LSW Tips & Tricks 22 09-09-2014 10:28 PM
CONVERT WAVE OR OTHER AUDIO FILES TO MIDI??? billymc MIDI 8 05-24-2006 08:49 AM
Convert Real Audio Files digimog Tips & Tricks 2 01-25-2005 12:40 PM
Importing from Sound Forge ,midi and audio files surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-18-2002 12:30 AM
Convert Cakewalk midi files to PTLE midi ? imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-18-2001 10:04 PM
