Deleting Unused Clips
I want to delete the copy Pro Tools made not the original, If select the option to delete rather remove will it preserve the original and delete Pro Tools copy to save disk space? or will removing do that as well as I select it but I'm afraid that x amount of copies will still be stored in the audio files subfolder of the session.
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) |
Re: Deleting Unused Clips
"Remove" will remove the clips/regions from your session. "Delete" will delete them from the hard drive. So, before you choose delete, make sure you do not need them.
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
hey J is there a short cut to normalize and activate the record on the channels on PT 10 Windows
I don't even cut clips I just mute them now . just as fast but always there. |
PT10 (HD?) BUG: Select Unused Clips | Bassturbator | Pro Tools 10 | 2 | 12-24-2011 10:52 PM |
deleting unused audio | AdamPT8 | Pro Tools SE and Essential (Mac) | 1 | 03-30-2010 02:54 PM |
Compacting without deleting unused | Karl Engel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-24-2006 06:50 PM |
Deleting unused audio | learning | Pro Tools M-Powered (Win) | 1 | 01-19-2006 09:48 PM |
deleting unused audio | merz | Pro Tools TDM Systems (Mac) | 6 | 10-23-1999 10:51 AM |
