Waves and S3L-X - Working solutions?
Is anybody using waves with the S3L-X system? What workarounds are tried and tested? Anybody tried connecting a soundgrid server directly to an E3 Engine? |
Re: Waves and S3L-X - Working solutions?
Hello Karel. There are not many options for you to integrate Waves with S3L-X. They are not running on AAX DSP and they want you to be using their software/hardware. What you can achieve is to connect you computer via the standard AVB integration MAC OS offers. Then run Multirack from Waves on that computer. Alternatively if you own they servers, you could use the AVB - MADI interface from Pivitec.
Sent from my iPhone using Tapatalk |
Hello Karel. There are not many options for you to integrate Waves with S3L-X. They are not running on AAX DSP and they want you to be using their software/hardware. What you can achieve is to connect you computer via the standard AVB integration MAC OS offers. Then run Multirack from Waves on that computer. Alternatively if you own they servers, you could use the AVB - MADI interface from Pivitec. Not really other options are there for you
Thanks, I know the theoretical options, I am looking for users who have tried and tested some options.
I own the Pivitec- Madi device, so that might be an option Gesendet von iPhone mit Tapatalk |
I saw a picture today with what looked to be a special version of Waves Multirack running in a Plugin Slot on an S6L
So where is the picture with the same being done on an S3L? |
So the solution for S6L is coming....... and the S3?
You could use a USB interface and run waves native on a computer. Connect the interface to all of the S3 and E3 analog and digital IO. That would give you 16 channels of insert etc.
How well is 'Waves Licence centre' working? | Ru_C | AAX Plug-ins | 22 | 12-16-2013 09:46 AM |
Waves 7.1 super tap 2 mod not working | francois | Pro Tools TDM Systems (Mac) | 0 | 04-26-2010 03:57 PM |
Waves Restoration and X-Click: Is It Working? | generator | Tips & Tricks | 4 | 07-02-2004 11:26 AM |
anyone had a problem with Waves Gold 3.2 and PT LE 6.1 working together | Justin_M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 08-11-2003 01:10 PM |
waves plug ins not working | Oddio | General Discussion | 1 | 02-20-2002 10:53 PM |
