Bad Audio & now midi?
I have a fast-track pro, a midi keystation pro 88, on an acer computer. I can't get audio playback, I'm getting signals in, but on audio tracks the mixer doesn't show any playback. I had reason working before, now that doesn't work either Also, I can't get the AISO driver working. So many problems...so little time! |
Re: Bad Audio & now midi?
Not sure, but I don't think ACERs are compatible with pretty much anything.
BUT.... How are you set up to record? Are you actually recording regions into PT, but you can't hear hem when you play back? You might need to change your "montioring mode" if that is the deal. I think...
Jon HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!) |
Audio MIDI setup says DIGI 002 midi device is offline | oliarnalds | MIDI | 17 | 10-23-2016 10:13 PM |
Multiple MBox Pro Instances/Icons in Audio MIDI Setup -> MIDI Studio | lpeckham | macOS | 8 | 04-24-2014 06:39 AM |
midi playback=audio, midi edit=no audio | Rubianes2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-18-2010 02:29 PM |
Audio MIDI Setup: Digidesign Audio Drop-down Item Disappears | TonyPT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-15-2007 05:43 AM |
When recording MIDI to Audio the audio, the audio timing isn't the same as MIDI | Justin_M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-09-2002 02:17 AM |
