Old 09-29-2003, 01:55 PM
buk50 buk50 is offline
Default what is DAE error -6001?
Working on an iMac, running OS 9.2, on a separate partician where I have installed ProTools Free.
I get this DAE error (-6001) every time when opening Protools Free. I click through it twice, then my session opens. Does anyone else, and do I need to change a setting, or something to make it go away.
Old 09-29-2003, 04:55 PM
M.Brane M.Brane is offline
Default Re: what is DAE error -6001?
The closest thing I could find in the Answerbase was DAE error -6008 which is a low memory error. How much RAM do you have?
Old 10-10-2003, 01:04 PM
The iMac I'm using has 386Mb of RAM. I've checked the preferred memory for DAE and ProTools and it is set to default settings. It hasn't happened in a while, so I'm OK for now. Thanks for your input.
Old 10-10-2003, 11:35 PM
That should be enough physical RAM. You might try bumping up the preferred memory setting on PTF & DAE. Just make sure you leave enough headroom for the system, and any other apps you might want open simultaniously, and don't change the minimum settings.
Old 10-11-2003, 01:21 AM
I found this with a search: "DAE was unable to communicate with the audio hardware -6001"
Make sure your sound control panel settings are set up correctly.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
HTML code is On
DAE Error -6001 mostevieplease macOS 1 08-14-2018 04:31 PM
DAE error -6001 was encountered RandB macOS 1 10-04-2012 11:52 AM
DAE Error 6001 Fletch88 macOS 4 08-11-2011 08:50 AM
DAE error-6001 was encountered CHUN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-17-2006 06:40 AM
dae error 6001 mark burman Digidesign Hardware & Software 1 06-07-2001 12:15 AM
