Old 11-06-2010, 06:40 AM
padraic padraic is offline
Default buzz on the eleven rack
Hey i was wondering if someone can help.I have the eleven rack and i use it as my interface on my imac. When ever i record using the eleven rack sounds there is a lot of buzz and does not sound good at all.Even the clean sounds have a bit of distortion and a lot of buzz.Yet when i use guitar rig 3 every thing sounds right,No bad buzz,nice and clean even though im still using the eleven rack as my interface.What can I do the clean up the eleven rack?
Old 11-09-2010, 04:04 PM
crashhak crashhak is offline
Default Re: buzz on the eleven rack
Do you think you can upload sound?
Old 11-09-2010, 04:16 PM
acmost acmost is offline
You sure you don't have the Cab sim bypassed?
Old 11-09-2010, 06:50 PM
zedhed's Avatar
zedhed zedhed is offline
Are you talking about noise that exists with no guitar being played, or noise that is introduced to the signal as guitar is played? or both?
Old 11-09-2010, 11:43 PM
from my experience, It seems when guitar cable touches the usb cable from external hard drive, i think I get buzz. I just turn off eleven rack and restart computer and works fine.
Old 11-10-2010, 12:07 AM
madgt621 madgt621 is offline
Location: Current: Ikebukuro, Tokyo, Hails from: San Francisco
just pointing out, USB hard drives aren't recommended for use with PT. They cause a whole lot of problems with the set up. Best not to use them in the first place.
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM
Pro Tools 10.0.0
Ableton Live 8.2.1
RME Fireface 800
Eleven Rack
Old 11-10-2010, 12:24 AM
Oh really! I didn't know, thanks for letting me know.
Old 11-10-2010, 08:27 AM
nst7 nst7 is offline
Also, make sure the 11R is plugged directly into a usb port on the computer, not into a usb hub.
Old 11-10-2010, 09:02 AM
Benoni's Avatar
Benoni Benoni is offline
unless you are on PC and Pro Tools 9, then Firewire drives are not supported. Again, ONLY for PT9 if you are on 8, then USB drives are not supported.
your best bet on either PC or Mac, for an external drive, is E-Sata. If you dont need portability than i highly recommend adding another internal drive or more.
Brian
Windows 10 Pro 64 Bit
Pro Tools 12 | Eleven Rack + ERXP
Youtube Channel - BenoniStudio
Free Eleven Rack Tutorials, Rigs, and more
@BenoniStudio
Instagram
Old 11-10-2010, 09:33 AM
cachosjazz cachosjazz is offline
i get a loud screeching noise when recording into protools.it never happened before.just started.then, my rack doesnt kick over.just sits there reading eleven rack.
what to do what to do.
Eleven Rack Output to Amp buzz antonis Eleven Rack 45 10-31-2017 06:59 AM
Eleven Rack Buzz CeresRegnum Eleven Rack 19 03-22-2013 11:41 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
The 002-Rack buzz, who's going laptop? pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-05-2003 03:56 PM
