Old 10-06-1999, 10:12 AM
Samhein Samhein is offline
Default HardDisk Jumper Settings
Hello Steve,
Would you know what the jumper settings on the harddisks should be when using the system with ProTools:
Terminator Power from Drive?
Terminator Power to SCSI Bus?
Drive furnishes power both to its own terminators and to SCSI Bus
Terminator Power from SCSI Bus
Enable/Disable Motor Start
Enable/Disable Parity Check of SCSI Bus
Thanks
Old 10-07-1999, 12:07 AM
Steve Rosenthal Steve Rosenthal is offline
Default Re: HardDisk Jumper Settings
Samhein,
No
Yes
Not unless you use the drive's internal terminators, in which case you'd have to jumper Term Enable as well.
No in most cases. Some SCSI controllers may be finicky and require this configuration. If so, you should be very cautious about your cable lengths, as Term Power will dissipate over the length of the bus due to resistance.
I'm not sure about this off the top of my head. If enabling it allows the drive to spin up at power-on (without requiring a start command from the host), then you should do so.
Parity should be enabled, but it must be enabled on all devices (including the host). If any device on the bus doesn't support parity, then none of the devices should be set to enable parity. It's all or nothing with this setting.
Hope this helps.
BTW, it's easier for me if you post these kinds of questions to the Storage section, since that's the main place I look.
Thanks.
--Steve Rosenthal, Digidesign ETS
[This message has been edited by Steve Rosenthal (edited 10-06-99).]
Jumper In/out optical adat flautista 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-03-2008 01:28 PM
Jumper Settings for External HD Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-12-2004 01:13 PM
apogee rosetta 800 jumper question ms.std Tips & Tricks 0 03-07-2004 10:43 PM
Quantum Atlas 10k jumper settings? digitalbaldur Storage Subsystems 1 06-18-2003 03:45 PM
IBM Deskstar 60GXP Jumper settings latenights 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-27-2001 08:38 AM
