Old 03-07-2014, 08:08 PM
Dave Modisette's Avatar
Dave Modisette Dave Modisette is offline
Default Melodyne track going out of sync.
I've had this happen twice.
After a period of edits (fairly long), Melodyne will lose sync with PT11 and play back delayed.
I have a sneaking suspicion it is related to conductor tracks because if I bounce the track, the clip that is problematic seems to be stretched out.
I hope to discover a recipe for this behavior.
Dave Modisette
www.gatortraks.com
Old 03-08-2014, 04:16 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Melodyne track going out of sync.
All versions on Melodyne are deeply related to your MIDI time (conductor tracks)
Plug-in? Single Track? Rewire? Standalone?
Keep in mind Single track references to the beginning of the session so if you have vari-tempos try to work in segments and print as you go (Have a routed audio track beneath your Mel track).
Converting anything to MIDI requires import from session start.
Make any conductor track (Tempo) changes while Melodyne is in use will goof the whole thing.
Old 03-08-2014, 05:00 PM
Gems Records Gems Records is offline
i wonder if this is in any way related to the autotune 7 loses tracking bug?
might indicate a flaw with aax implementation on avid's end of things
Intel i7 930 2.8ghz, dual 500gig raid 0, 1 tb audio drive, ati radeon 5560, M-Audio Projectmix io, Motu 896 HD through adat
Old 03-08-2014, 06:19 PM
Top Jimmy's Avatar
In the past, I have had Melodyne lose sync while transferring. I learned that when transferring audio into Melodyne, I needed to keep my hands off the keyboard and mouse. Any activity done while transferring could screw it up. As long as I leave things alone, I don't get any sync issues. Once done transferring, life goes on.
James Cadwallader
Old 03-08-2014, 08:21 PM
mesaone mesaone is offline
In my experience, melodyne is hard to work with. It refuses to sync when in rewire (melodyne editor standalone) and the plug-in version is difficult to use because it cannot control the transport. I've not experienced it going completely out of sync, but I commonly get drifts that I have to manually correct after printing. It's a disappointment.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 03-08-2014, 09:50 PM
Andrew. D Andrew. D is offline
I'm going to guess here that you have multiple tempos through the song.
Melodyne doesn't handle tempo changes very well, especially if you start your initial transfer after the song start, say at the first chorus. It will be fine as long you are playing the selection you transferred but once you go outside of this it will lose sync.
The solution is to start your transfer from bar 1 and continue on until the end of the song, which is a pain if all you are wanting to fix is the last line of the song!!
I have also read that if you turn the conductor track off it will stay in sync although I have never tried this.
Hope this helps
Mac Pro, Mid 2010 dual 3.33 Ghz, 64 Gig RAM
Mac OS 10.14.5
ProTools Ultimate 2021.6
HD Native PCIe
Apogee Symphony I/O
Avid HD I/O
192 I/O
Waves DLI
Apogee Mini Me
Mbox Micro
Old 03-09-2014, 06:27 AM
Hanswurstlsepp Hanswurstlsepp is offline
If there's a tempo change in your PT-session, you have to let MelodyneEditor learn the tempo change(s) of the DAW-host.
http://helpcenter.celemony.com/edito...k_tour_72.html
Pretty simple process. If you will use more MelodyneEditors within the same PT-session, just let it learn the tempo and save it as a PT-PlugIn-Preset and recall that setting before transferring audio from another track.
Doing this pretty often and never had a problem.
But if it's a straight tempo within your PT-session and you are running into "out of sync issues" I got no idea what could be wrong beside the usual trouble shooting stuff (trashing Melodyne/PT prefs etc.).
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
HTML code is On
Printing melodyne track RobinWinjil macOS 8 10-31-2013 02:53 PM
Melodyne out of sync on PT 8 joedexter23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-02-2012 07:14 AM
Melodyne won't sync! Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-20-2009 03:45 PM
Can't sync audiofile with Melodyne DavidHeylen Virtual Instruments 1 04-08-2009 11:21 AM
Melodyne -are multiple track edit groups possible? Vaporhead Pro Tools TDM Systems (Mac) 4 04-25-2006 12:12 PM
