Asymmetrical waveform (problem?) caused by 7-Band EQ 3
Hi. Please help. I just mixed a TV documentary with predominant sound being voice-over and talking heads. Everything sounds ok but my final waveform looks like this (the parts going below the line is voice-over, and the others, usually going above the line are talking heads recorded with lavalier mics). Hardly anything is symmetrical. I realized that the 7-Band EQ 3 causes this, as when I bypass it - it everything looks symmetrical. I use High pass filter usually around 90 Hz, low pass around 13khz and other equing between that. Other than that I use Renaissance compressor, Massey de-esser and L1 on master channel, but none of these causes that. Also, when I put a really steep Q10 filtering out everything below 100hz everything looks more symmetrical, but why would I do that. I thought it is a DC problem but I tried DC removal both on clips and the sections of bounced file but everything stays asymmetrical. By the way I am still on PT 7.3.1 with DV Toolkit.
Is this a normal thing, should I worry about this asymmetrical waveform? Tnx! Last edited by lynx lynx; 08-15-2014 at 03:21 PM. Reason: correction |
Re: Asymmetrical waveform (problem?) caused by 7-Band EQ 3
very few things at truly symmetrical
I wouldn't worry unless it sounds off
If you have a proper monitoring environment and it sounds good, why would be a reason to worry???
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
Tnx a lot, I will not worry as it sounds good. but does anyone know why 7-band EQ is doing this, as I understand it has something to do with low frequencies.
Looks like a dc-offset. Try lo-cut at 20Hz.
eq 3 1-band problem | oplatner | Windows | 7 | 07-15-2012 11:53 AM |
recording band problem | m4ca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-09-2008 11:23 AM |
7 band EQ problem | johng90 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-18-2006 10:16 PM |
Equiem 7 Band EQ plugin a problem.... | loungecat | Pro Tools M-Powered (Win) | 1 | 06-05-2006 01:50 PM |
latency problem caused by waves pluggins? | Calvin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-29-2002 02:33 PM |
