Re: The Mic Signal is Low?
I don't like the multifunction knobs and buttons of the Omni.
I wish they would make individual knobs for the headphones, monitor and micpre sections instead. maby something like this : http://protools.ideascale.com/a/dtd/...olt/80068-3779 |
Hi All,
I got the HDOmni replacement, the front 1,2 mic/lines/inst working fine (as expected) , the 1-4 inputs analog (in the back) still have the same issue (can't reach more than 50% from the input signal level) I already update to PT HD 9.0.5 and there is no issue except the above issue. AVID SUPPORT: could you please advise me, is there anything I need to do? |
here is the Sandra report
============================================== SiSoftware Sandra Computer Model : GigaByte EX58-EXTREME Workgroup : WORKGROUP Host Name : Ali-PC User : Ali Processor Model : Intel(R) Core(TM) i7 CPU 975 @ 3.33GHz Speed : 3.5GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : GigaByte EX58-EXTREME BIOS : Award (OEM) F12 03/11/2010 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 3.24GHz (6.48GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 3.24GHz (6.48GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 400MHz Memory Module(s) Memory Module : OCZ OCZ3X1600R2LV2G 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3X1600R2LV2G 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3X1600R2LV2G 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3X1600R2LV2G 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3X1600R2LV2G 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3X1600R2LV2G 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-16 4-26-8-4) Video System Video Adapter : NVIDIA GeForce 9600 GT (Microsoft Corporation - WDDM v1.1) (64 SM4.0 1.6GHz, 512MB DDR3 1.8GHz 256-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce 9600 GT (Microsoft Corporation - WDDM v1.1) (64 SM4.0 1.6GHz, 512MB DDR3 1.8GHz 256-bit, PCIe 2.00 x16) Graphics Processor Storage Devices WDC WD1001FALS-00U9B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (D:) (F:) WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5") : 2TB (E:) WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:) HL-DT-STDVD-RAM GSA-H55N (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices PT (D:) : 195GB (NTFS) @ WDC WD1001FALS-00U9B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) LIB (E:) : 2TB (NTFS) @ WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5") WIN7 (C:) : 466GB (NTFS) @ WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) BackUps (F:) : 736GB (NTFS) @ WDC WD1001FALS-00U9B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) 3.5" 1.44MB (A:) : N/A Optical Drive (G:) : N/A @ HL-DT-STDVD-RAM GSA-H55N (ATA66, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Giga-Byte HD Audio Controller Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Network Services Network Adapter : Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet) Network Adapter : Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) #2 (Ethernet) Wireless Adapter : Compact Wireless-G USB Adapter (802.11g (ERP), AES-CCMP, 54Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.8 ============================================== I hope someone can help |
Hey,
This may be a silly question, but have you tried changing the Input trims in Hardware Setup for your Analog inputs? I too was getting very low signal with my outboard gear until I changed my Input Trim Settings. Just a guess. Good luck!
_______________________________________________ Win7 x64|HP Z600|2 Intel Xeon @ 2.93 GHZ|24GB DDR3 PC3-10600 ECC RAM| OCZ Vertex 2 SSD 128 GB 3.5 Sys HD|600 GB WD Velociraptor Audio HD| 1GB Samsung 840 EVO Sample Library HD| PTHD 10.3.6 & 11.1.3|HD Native Core|Lynx Aurora 16 HD|Dangerous Monitor ST| UAD2 Octo Core Card |
Thanks |
Just take your unit back to the dealer and get them to sort it out. That's what I did. My dealer gave me a loaner and sent the unit off to Avid. I just got an email from Avid today saying that it's on it's way back now. It doesn't have anything to do with your computer or your version of PT.
JR
J.R. Fountain credits: www.imdb.com/name/nm0288354/ system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12 |
In fact this is HDOmni replacment and the front inputs (1,2) the Mic / Inst working fine. I just can't get more than 50 to 60 % max from the back analog in 1-4 in the input signal. and I think this time it's not a hardware issue... I am new to HDOmni and I think I might need to do some configuration or sound setup in the HDOmni. Hope someone can help.... |
Was this issue ever resolved? I'm having the same problem with my dynamic SM-57. Everything is running fine but my mic signal is only registering a little and I'm beginning to think it's my Fast Track Pro.
Thanks |
No audio signal or midi signal after pro tools 8.04 upgrade | allgenres | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-01-2010 08:58 AM |
aux track signal but no midi signal? | elv1s1sal1ve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-06-2005 07:18 PM |
No Midi signal, no audio signal, buzzing monitors! | 1tonstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-26-2004 07:01 AM |
Using one signal to lower the volume of a second signal for distance learning? | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-23-2003 12:54 AM |
synced with pro tools- see signal, but can't hear signal- HELP!!!! | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-30-2002 10:08 PM |
