Old 04-28-2017, 09:23 AM
jgirv jgirv is offline
Default older i7
hi all,
actually, everything works quite well... just wondering how under-powered my lap top is for anything approaching a full session with a few plugs...
about a 7 year old DELL running W10, with an i7 processor... but it's prob a first generation i7... hard to find info directly related to DAWS that discusses the relative power of the processors...
any ideas or experience with this?
I was able to simultaneously record 8 tracks via a Scarlett 18i20 with not too much issue.
Old 04-28-2017, 09:45 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: older i7
It would help to have the full specs. but depending on what you want to do you might be fine. Here are the requirements - http://avid.force.com/pkb/articles/e...m-Requirements It will depend greatly on the VI's you're planning to use, and how many instances, along with other track counts etc.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-28-2017, 12:43 PM
And adding RAM might give a simple boost. My first i7 machine(socket 1366) runs great with PT10, but was dragging with PT12. Swapping 12GB of RAM for 48GB made a big improvement. I doubt your laptop can handle that much RAM, but if you are at 4GB now, going to 8(or 16)GB could make a big difference. Also, if you are running a typical 5400 rpm laptop system drive, updating that to a good SSD would give a lot better feel(Samsung 850 EVO is a great choice. 840 EVO is very close. 850 Pro is probably the best choice but can be expensive).
Old 04-28-2017, 03:18 PM
Assuming it's a first generation 920 4core, the modern equivalent is way over twice as powerful in terms of Pro Tools Benchmarking.
Do either of the tests from the post below and I can give you pretty solid numbers on the difference. I would also need your PT version and interface.
http://www.pro-tools-pc.com/performa...ing-pro-tools/
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 04-28-2017, 08:09 PM
Thank you everyone for your very helpful replies and solid info. Much appreciated!
Old 04-29-2017, 01:11 AM
Transputer Transputer is offline
Look in Control Panel\System and Security\System for your cpu
I've an HP DV6 2106ea 1st generation i7 - CPU is the Intel Core i7-720QM.
Old 06-30-2017, 01:42 AM
peterle peterle is offline
the cpu shouldnt be the culprit , at least if it is a 4 core , most problems are RAM and
outdated Graphics components in theese Laptops ...
if not using very cpu-heavy plugins (NI GuitarRig f.e.)or instruments it should work fine if you have enough RAM , ssd pretty recommended.
Of course modern i7 are a lot faster , point is if you need THAT MUCH faster which is not that much.... , if you compare REAL Sessions on different i7
systems with the same amount of RAM , the difference is not that much
and in most cases the old i7 is sufficient.
Mostly the bottleneck is anywhere else.
foley artist , soundeditor
Old 06-30-2017, 05:22 AM
Thanks for the observations, shows a real understanding of how these things work. Also explains why my old box still performs certain tasks really well and others not so much.
updating older PT LE on older Mac skfdude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2013 01:03 PM
Question about an older Mac Pro and possible older versions of Pro Tools HD wolfman_rob Pro Tools TDM Systems (Mac) 13 07-21-2013 01:29 AM
Best use for an older 867 G4 carlos2909 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-17-2004 07:41 AM
Here's a Tip for OSX & older G4's lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-22-2004 06:27 PM
older AGP 400 mhz G4s RobbaDobba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-27-2001 09:14 PM
