Waves 3.5 and PTLE freeze ups
Well, the new version of the Waves Renaissance Collection does run much more efficiently
on my Athlon-based system. However, on occasion when opening a Waves window (ie for an EQ plugin on a track) PTLE freezes. My PTLE has been stable for months. Sometimes this corresponds to an error dialog (...operating system holdoffs...), but not always. Has anyone else had this experience? Also, when I have the Windows multimedia set to digi001 channels 1-2 for normal windows sounds, PTLE sometimes can't acquire the hardware. If I change this multimedia setting PT seems to work fine. Any help with either of these problems will be greatly appreciated. I'm still able to record/mix, but I have to arm-wrestle my computer with musicians watching me. thanks |
Re: Waves 3.5 and PTLE freeze ups
i've had similar problems with waves plugins. you're right about the "operating system holding off interrupts too long" message. that's the culprit.
here's what's happening: you pull up a plug and PT goes bonkers and gives you that error. the problem is that the error dialog box is BEHIND the plugin window and they're both stuck until something happens to one or the other. you need to pull that error dialog box up to the front. here's the solution: hit ctrl+alt+del ONCE! the windows end program dialog box will appear. then hit ESC and the end program dialog box will disappear and the PT error dialog box will come to the front. hit the ok button and everything will go back to normal.
i love my apple iPhone! |
Thanks.. I did notice that small dialog box. It seems that when this error
happens Windows becomes unstable. PT won't shut down, etc. it's more of an irritant than anything else. |
Waves plugins GUI freeze | Boe Larsen | Pro Tools TDM Systems (Mac) | 10 | 11-03-2016 01:34 PM |
Masters Waves Freeze MP8 | arnisteinar | Pro Tools M-Powered (Win) | 6 | 03-30-2012 04:46 AM |
Pro Tools 8 Waves AudioTrack V7 freeze | PTL81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-17-2010 06:33 PM |
Waves ?? freeze... | Conra | Pro Tools TDM Systems (Mac) | 0 | 04-16-2004 10:04 AM |
Waves & keybrd + mouse Freeze! | Rob Macomber | Pro Tools TDM Systems (Mac) | 4 | 11-13-2001 06:40 AM |
