Old 11-18-2003, 03:34 PM
hookiefree hookiefree is offline
Default I Can\'t Monitor Input Levels
When I try to record Midi tracks as audio I can't monitor the input levels on the audio track unless I'm actually recording. Even with the audio track armed nothing happens when I press play. I'll see the MIDI levels jump, the Aux levels too if I'm using one. If I mute the Aux track or delete it, arm the audio and press play I don't hear anything but when I hit stop I hear the end of the note. I've done searches already and I'm sure my connections are right because I've been doing it the same way since I've had PT. I only noticed it since installing 6.1. Is this a known bug or something?
It's finally starting to come together
Old 11-18-2003, 04:33 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: I Can\'t Monitor Input Levels
Monitoring- change from Auto Input to Input only.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 11-18-2003, 06:18 PM
You da man Cliffy!
Help - I can't monitor input levels unless recording. tj7 macOS 20 05-06-2013 08:15 PM
MBox 2 Pro Monitor knob has stopped changing monitor levels Rumandolin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2013 09:13 AM
switch auto input and input only monitor with midiprotocol mmestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-27-2003 03:51 PM
Mix levels vs. monitor levels badshirt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-05-2001 12:17 AM
How to toggle between "auto input" and "input monitor" with PC?? Camilo Orozco ProControl, Control|24, Command|8 2 04-23-2001 01:05 PM
