Old 11-28-2014, 07:00 PM
kokomiko kokomiko is offline
Default Pro Tools 11 cannot communicate with M-Audio keyboard / HUI
Hello,
I have a normal clean win 8.1 installation with the latest Pro Tools 11 installed. Just an M-Box is connected, nothing else.
I tried to connect the new M-Audio Oxygen 49 Mk4 controller/keyboard, configured the Setup/Peripherals settings correctly and everything looked fine...execept it did not work . Pro Tools did get no MIDI data and after a minute there came a popup window saying "Pro Tools cannot communicate with the M-Audio..." not giving any details.
After that I tried the Arturia Keylab 49 keyboard. The Setup is a little different but i followed the instructions from the Arturia Website for Pro Tools. The result was exactly the same... "Pro Tools cannot communicate with the HUI..."
I tried to analyze the problem, but did only get that far that under windows itself with other apoplication everything works perfectly. All the stand alone players from my plugin instruments for example run without any problem. I also checked the MIDI data with a control program and it all was fine.
Just Pro Tools seems to be the problem
as Pro Tools is not give any hint about the reason ( just saying restart the device , which doesn't help), it would be great if someone could help...
thanks a lot in advance. !!
Old 11-29-2014, 09:27 AM
jensonph jensonph is offline
Default Re: Pro Tools 11 cannot communicate with M-Audio keyboard / HUI
Hey i just posted the same problem, stumbled onto something, it said to disable controller in peripherals, close pro tools, then right click ptools to run as administrator, thrn setup peripheral again, m going to try now
Old 11-29-2014, 09:56 AM
Did not work for me
Old 11-29-2014, 10:29 AM
Someone got back to me snd is functioning i had to create a midi track, set the midi controller as input, the plug in as the output, then enable record, not sure if this helps.
Old 11-29-2014, 05:39 PM
neither running PT as admin nor the settings did change anything. the problem must be somewhere else :-( but thanks
Old 12-02-2014, 12:34 AM
popajoe popajoe is offline
http://www.youtube.com/watch?v=xOeqgw61VcE Try this for M-Audio keyboards if you need more call the candy store SW.
Old 12-19-2014, 05:33 AM
sound_bites sound_bites is offline
This worked for me:
Don't go to setup>peripherals!
1. create an insrument track
2. call up an instrument plugin
3. input should be set to receive midi on all devices
4. output to the loaded device on midi channel 1
5. make shure midi through is enabled!!
6. record arm the track
you should now be able to trigger sound
Old 12-21-2014, 06:54 PM
Since doing this my kontrol audio 6 interface isnt workibg with pro tools, still works with reason, amplutube and everything else ive checked, it says it cant initislize, i have tried every sample rate with no difference, any help would be appreciated
Old 12-21-2014, 08:07 PM
Just recalled that the changes i made in peripherals may be the cause, unfortunately i dont know what would be correct
Pro Tools is unable to communicate with M-Audio Keyboard mstreacy Windows 27 11-08-2017 08:22 AM
DAE was unable to communicate with Audio Hardware harrillj Pro Tools TDM Systems (Mac) 1 12-31-2006 05:59 AM
PCI Bus is too busy for DAE to communicate reliably with audio hard drive* why!??? Target Earth Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-16-2001 09:36 AM
DAE UNNABLE TO COMMUNICATE WITH AUDIO HARDWARE..... BARBACOA Pro Tools TDM Systems (Mac) 0 10-06-2000 02:41 PM
DAE cannot communicate with audio interface noslouch Pro Tools TDM Systems (Mac) 3 05-03-2000 08:34 PM
