Old 09-27-2014, 09:46 PM
damasio damasio is offline
Default record midi in loop overwrites everything. How to merge notes?
I can't figure out how to manage midi note recordings in loop.
Midi notes are overwritten while recording in loop mode. I want to merge midi notes in loop recording in stead. How can i achieve that?
The midi merge button in transport is greyed out, and i can't select it for unknown reasons.
thanks
System Details
Old 09-28-2014, 10:38 AM
zixis9 zixis9 is offline
Default Re: record midi in loop overwrites everything. How to merge notes?
Ive never used loop recording for midi (just audio to work out parts). I simply do my main midi part to satisfaction and then merge additional parts as needed to satisfaction, then eventually its all there for the final edit before transferring to audio.Thats my workflow. FWIW
Old 09-28-2014, 11:41 AM
Glenjb Glenjb is offline
You need to disable Loop Record mode for midi merge to work but you can still record using midi merge while looping. Here is a quick video I found explaining how:
https://www.youtube.com/watch?v=q_1DI5_Rbmo
Why cant i loop record while using midi merge? bandagedhand MIDI 5 01-13-2012 04:05 PM
Fastes way to merge midi notes Talisker Pro Tools 9 14 12-20-2011 09:59 PM
NO Midi Merge in Loop Record, Solution? jnorten MIDI 9 12-13-2009 09:59 PM
MIDI MERGE LOOP PLAYBACK AKELCO MIDI 7 08-20-2006 04:18 PM
MIDI Merge function causing stucked notes SoundReplay Pro Tools TDM Systems (Mac) 0 07-26-2006 08:23 AM
