Old 08-17-2006, 05:16 PM
beggehorn beggehorn is offline
Default Help menu/PT Reference Guide greyed out in 7.2??
After upgrading to 7.2 and installing the "7.2 doc's", ProTools is not finding the PDF for the PT 7.2 Reference Guide. I have verified that the PDF exists in the C:\Program Files\Digidesign\Documentation\Pro Tools directory. Is anyone else seeing this? I can manually browse to the file and open it, but it would be great if the menu shortcut would work.
Windows 10 Pro x64
Avid HDX running PTHD 2018.x (latest)
ASUS P6T Deluxe V2
Intel i7 Core 920
12 GB RAM
Matrox M9140
Avid Artist Mix
Old 08-17-2006, 07:16 PM
manichouse manichouse is offline
Default Re: Help menu/PT Reference Guide greyed out in 7.2
I had this happen too. Then one day it was mysteriously available again, so I never attempted to troubleshoot it.
Martin Trum
Old 08-17-2006, 07:51 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Help menu/PT Reference Guide greyed out in 7.2??
In Pro Tools HD 7.2, the manual is named "Pro Tools Reference Guide.pdf". Check to see if that is what it is named, and if not, rename it and see if that works.
Administrator
Old 08-18-2006, 10:27 AM
Thanks for the replys. Yes, the file is correctly named. I should have also mentioned that ALL the resources in the Help menu are greyed out and yet they all appear in the correct folder except for "DigiRack Plug-Ins Guide" which I can't find a PDF for (a windows search brought up nothing).
Windows 10 Pro x64
ASUS P6T Deluxe V2
Intel i7 Core 920
12 GB RAM
Matrox M9140
Avid Artist Mix
Old 08-18-2006, 06:53 PM
steve at Your Heaven steve at Your Heaven is offline
I've had this problem for some time - a year or so? Using 6.7. The pdf's are in the correct file folder, I have at least once done a re-install of Protools.
I gave up, and put a shortcut to that pdf folder on my desktop. I guess that's all the HELP menu is anyway, a shortcut to that folder's pdf's.
steve
Your Heaven
Old 11-17-2006, 04:49 PM
This problem still exists in PT7.2cs2...
Any chance on getting this resolved Digi?
Windows 10 Pro x64
ASUS P6T Deluxe V2
Intel i7 Core 920
12 GB RAM
Matrox M9140
Avid Artist Mix
Old 11-18-2006, 09:58 PM
Avid's Avatar
Administrator
Have you already tried deleting the reference guide, then running the documentation web installer again?
See if that works. You can download the installer from here:
Pro Tools HD 7.2 Documentation Installer
Administrator
Reference Guide and other HELP MENU items. ISLANDER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-23-2011 04:18 PM
Pro Tools Reference Guide Grayed Out in Help Menu npratt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-25-2008 06:35 PM
reference guide in pt documentation, not in pt help menu? tonegiver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-24-2007 04:00 PM
7.3 Help menu is greyed out original_min 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-09-2007 07:18 PM
Getting the Reference Guide back in the Help menu RandB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-03-2006 09:50 PM
