Re: Advice On Mac OS update from 10.15.7 --- or not
I am currently running the same machine as the OP (2019 MBP i9) with Catalina.
Latest version of Ultimate and a Avid Carbon. I have been holding off for fear of loosing/breaking something in the update to OS11/12. The only thing that I feel left out with is not being able to run the latest version of Logic and FCP. I have since transitioned from FCP to DaVinci and for the first time in about 30 years I'm not up to date with Logic (Been running Logic/Notator since the days of the Atari-ST). The system is rock solid and does everything I need it to do. But I have a bad case of FOMO |
There is Sidecar, but it doesn't work very well - I wouldn't want to use it while doing anything important. More emojis. A different typeface. Notifications are slightly different. Icons in the menu bar are slightly different...... I use both, and really don't care which is which. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
On another note, monetary value means nothing if something is functional. I upgraded computers when I started getting into video but for Pro Tools, I'm not running live tracking sessions nor using huge amounts of plugins or VIs and don't use sample libraries. Pretty much I record myself and, at most, program drums. There may yet be more Pro Tools life in the 2015 machine!! Thanks very much for your input. |
#16
#17
So I just got a request from a client to do a session in Logic 10.7.x for composition then transfer to Protools for mix. So I might have to do the upgrade anyway. Now my biggest question is do I go BigSur (minimum to run Logic 10.7) or just go straight to Monterey !? MBP 2019 i9 10.15.7, Avid Carbon,Protools Ultimate, Logic 10.6.x |
#18
#19
Since posting last I had a situation where I needed to run Cubase Pro 9.5 to exchange a session with a guitarist friend in Nashville. I tried Cubase Pro 9.5 on Monterey and it sucked monkey nutz big time so I bought an external NVMe to USB 3.0 adapter and a cheap 500Gb NVMe drive to install Mojave on, worked like a champ. Might be an option to retain an older MacOS for software compatibility.
Advice: looking to update system | Serip | General Discussion | 3 | 11-17-2011 10:58 AM |
Advice for update to system...? | Clarke | Pro Tools TDM Systems (Mac) | 3 | 03-10-2011 05:33 AM |
Need advice on update | Vashta Nerada | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-28-2011 06:56 AM |
Need new update advice 8.0.3 cs1 | flautista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-22-2010 12:26 AM |
seeking advice on update, 6.4 to 7.? | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-01-2008 01:58 PM |
