Old 07-25-2002, 10:05 AM
radioface radioface is offline
Default plugin ? stereo vs. dual mono
is there a huge difference in using plug ins as stereo or dual mono??? on an audio track, a master bus??? How does this apply to the waves stuff...any opinions out there?
Old 07-25-2002, 10:41 AM
Ben Jenssen's Avatar
Default Re: plugin ? stereo vs. dual mono
I think there is no difference in sound at all. Why should there be?
Some plugins only work in dual mono, thats all.
Old 07-25-2002, 10:42 AM
bassmac bassmac is offline
As far as I know, dual mono came about before stereo, and uses the DSP equivalent of two mono plugs. I believe stereo uses about, or the same DSP as a single mono plug.
Old 07-25-2002, 10:49 AM
i was just curious if the architecture of the plugins themselves might dictate a different behavior depending on the way in which they were utilized.
much obliged
Old 07-25-2002, 11:28 AM
rsmith123 rsmith123 is offline
Dual mono vs stereo can make a huge difference with compression. It can make the sound bounce back and forth between the speakers. Be careful.
Flame converting stereo to dual mono EarHole Post - Surround - Video 12 09-26-2013 03:06 PM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 09:01 AM
Bounce to disk - stereo or dual mono? mjames08 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-19-2002 01:56 PM
true stereo vs dual mono LATablette 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-18-2002 01:52 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
