Old 04-02-2015, 07:58 AM
WolfScream WolfScream is offline
Default Problem with Moving Multiple Clips in Timeline - Some Disappear
The issue I am having is when I select multiple clips in the timeline and then try to move or nudge them, some of the clips disappear. I used Pro-Tools Version 8 for years and never had the problem until I upgraded to 11. I just selected as many clips as I wanted and then moved all of them at once, to wherever I wanted. I've tried all of the link buttons but can't seem to find a solution. Also, when trying to consolidating clips sometimes, it will only consolidate some and leave another part of the clip separate....quite odd. I imagine it probably is a simple fix...unless it is some bug in my software. Everything else works well though and I have re-installed the software twice. Anyone seen this before or know the solution? Thanks much for the assistance.
Old 04-03-2015, 01:52 AM
Stig Eliassen's Avatar
Default Re: Problem with Moving Multiple Clips in Timeline - Some Disappear
Welcome to these forums.
What is your setup? Mac? PC? Pro Tools (11.x.x) and OS version?
—> Help us help you <—
Old 04-06-2015, 06:00 AM
Thank you. I always seem to be away from my Editing machine when I need that information. But, I'll give you what I can remember PC, Windows 7 - 64 bit, 8 GB RAM, Pro-Tools 11 (Not sure which version of 11, but I ordered from Sweetwater and haven't changed the version) I will get the specifics this evening and place in my AutoSig going forward...
Thanks again...C Wolf
Old 04-06-2015, 05:05 PM
More precise Statistics:
Pro Tools 11.0.2 on a PC with Windows 7 64 bit - AMD 8-3850 APU 2.9ghz 8GB RAM - Focusrite Sapphire Pro.
Old 04-07-2015, 05:27 AM
Since you're on Windows I can't really be of much assistance. 11.3.1 is the latest version, with lots of fixes and improvements. Check out the Read me (pdf).
Avid Knowledge Base
Old 04-07-2015, 05:47 AM
Thanks for the response Stig, not a problem. I'll try and upgrade to the latest version of PT 11 to see if that helps. C. Wolf
Old 04-07-2015, 07:44 AM
Sounds good. I'm sure someone will help you if you're still having issues after the update.
moving clips fmilian Pro Tools 11 6 05-08-2015 05:11 AM
Moving location markers with the clips? Yumid Getting Started 12 09-20-2014 02:45 PM
moving all the clips! TakenGrace Pro Tools 11 6 06-21-2014 01:07 PM
Distribute clips on the timeline at regular intervals? iain_m Pro Tools 10 8 09-22-2013 07:27 PM
BUG: All Clips in Edit Window Disappear! conleec Pro Tools 10 3 01-17-2012 10:13 AM
