Old 10-24-2013, 07:08 PM
djcartledge djcartledge is offline
Default AVB64 drivers
Hi. wondering if anyone has come across this message when installing ABV64 on mac. It comes up and says that there is no AVB hardware in the mac. That the S3L is AVB equipped and working and Cat6 to the Imac GB port.
When the software package is run, it fails immediately with this error.
Dave
Old 10-24-2013, 08:28 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: AVB64 drivers
Hi Dave,
First thing to check is that the Mac meets the system requirements, located here.
All Macs with a thunderbolt port also have the AVB chipset; this is the easiest way to tell. If the Mac doesn't have a thunderbolt port it likely is not compatible.
Sheldon
Old 10-25-2013, 03:57 AM
Thanks Sheldon. The bit I missed was that all the macs below must be fitted with a thunderbolt port. mine doesnt meet that.
oh well time for a new one
Old 10-25-2013, 06:23 AM
Hi Again.
ok so now I have my macbook pro 13 which is equipped with a thunderbolt port. and i get the same message on it.
now im stumped
Old 10-25-2013, 12:31 PM
Valentyn Valentyn is offline
Originally Posted by djcartledge View Post
Hi Again.
now im stumped
What OS X version do you use?
Old 10-26-2013, 03:19 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Dave,
Can you check if the FW of the TB port is up to the latest firmware ?
http://support.apple.com/kb/DL1653
I've seen a 'manual' download and installation of the TB firmware fix the issue that you are seeing.
One important requirement as well when using the AVB enabler is that you have to have the TB to ethernet adapter plugged into the thunderbolt port. If it is not plugged in the enabler will fail because it does not see an available port to enable.
Hope that makes sense.
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 12-19-2013, 10:33 PM
zachary_avedim zachary_avedim is offline
Is the Avid AVB enabler working on MAC OSX 10.9.1 ?
I'm getting the "AVB interface Not found" error...
Old 12-20-2013, 11:18 AM
Kristo Kotkas's Avatar
Kristo Kotkas Kristo Kotkas is offline
See my post here about Mavericks: http://duc.avid.com/showpost.php?p=2106373&postcount=1
VENUE FAQ & download links, useful
AVID VENUE ILok driver download
VENUE Plugin DSP usage
My AVID:
  • Room A > HD4Accel PCI-CustoMac / 192D / PTHD10 / 2 x Artist Mix / Artist Control
  • Room B > HD3Accel PCI-CustoMac / 192D / PTHD10 / 2 x Artist Mix
  • Big Live > VENUE Profile 48/24 + 2nd Snake card, IOx, FWx, HDx, PQ Rack, 8 x PQ Controllers
  • Small Live > S3L-32 + Mac Mini - two systems - combined one 64/32 FOH / Mon setup
  • On stage > Pro Tools on laptop with variety of M-Audio boxes
Old 12-21-2013, 01:37 AM
Thanks Kristo. It's working now
Another thing is, I'm not able to get the Console AES inputs to show up in protools 11. Is that a limitation to the system?
Old 12-21-2013, 01:38 AM
I mean the E3 Engine AES inputs that are patched to the input channels, aren't going through to ProTools
003 Drivers tmitchell Pro Tools 10 6 10-27-2013 03:24 PM
Drivers MandoDjango 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-19-2009 10:51 AM
HUI drivers.... edytnbch Pro Tools TDM Systems (Mac) 1 04-12-2005 04:14 PM
OSX drivers or proprietary PT6 drivers-what will it be? pfd4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-02-2003 02:04 PM
