Problem with 003 rack Clock Source in PT11
Helllo,
I use a 003 rack with an Octopre II. In PT 10 I could set the Clock Source to ADAT (if I didn't, recordings would have pops). But in PT 11, I can't seem to do that. The dropdown is there in my hardware settings, but no matter what I choose, 'Internal' remains selected. Does anyone know how to fix this? Thanks! Jack |
Re: Problem with 003 rack Clock Source in PT11
If you're using the 003 as the default windows audio device, don't. Then you can try trashing prefs.
http://avid.force.com/pkb/articles/e...ry=#delete_pro
Thanks, I'm going to try that!
Not sure if this will help, but on my system, with PT11, when I go to change the clock source to my External Wordclock, it takes about 5-6 seconds between selecting wordclock, and it actually changing in the window(where in PT10, it happens instantly)
Awesome, just had this problem, and removing the 002R as the Windows default audio device was the solution! It still has a telephone icon by line-out 1&2 but seems to work fine!
Thanks! |
Problem detected with audio clock. Check your clock source and sample rate. | sleeptalken | Windows | 7 | 08-10-2021 01:17 PM |
Problem detected with audio clock. Check that your clock source and sample rate are c | Solow1nonly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-06-2011 08:22 PM |
problem detected with audio clock. check that your clock source and sample rate are c | angeleda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-05-2010 07:09 PM |
Error: "Problem detected with audio clock. Check that your clock source and sample... | mongo_man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 28 | 05-01-2010 06:08 AM |
"Problem detected with audio clock. Check that your clock source and sample......... | ASD15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-26-2010 03:40 PM |
