Instrument Track Plug In Input Bug
I use Protools in conjunction with VEP5 for my music production. I am trying to import instrument tracks from one PT session to another using "import session data". When I do this, my input settings on the imported instrument tracks are deactivated (greyed and in italics). When I try to re-select the appropriate inputs (Plugin Inputs which are being fed from VEP5 instrument track outputs) PT bumps the input selection to an unwanted input and prevents me from selecting the input I want.
For instance. Let's say I have a ProTools session with a performance on an instrument track that I want to import into a new session. In the original PT session I have an instrument track receiving audio from an instance of Kontakt in VEP5. The Kontakt output in VEP5 is set to Channel 21+22 as is the input on the instrument track in PT (plugin input: 21+22). Now I start a new PT session and what to import that same PT instrument track to the new session using "import session data". The track is imported with the correct inputs selected and the midi data in place, but the input selection is inactive (greyed and in italics). If I try to re-select the input (in this case plugin input 21+22) the input selection bumps to some other input, like 59+60. No matter what I do, I can not select input 21+22 on that track. Very strange!!! This is extremely frustrating. Can anyone shed any light on this situation? Thanks in advance! |
re: Instrument Track Plug In Input Bug
I'm having nearly the exact same problem - PT bumps the plugin input selection to an unwanted input and prevents me from selecting the input I want.
If I have a ProTools 12 session with a performance on an instrument track receiving audio from an instance of PLAY in VEP5. The PLAY output in VEP5 is set to Channel 21+22, as is the input on the instrument track in PT (plugin input: 21+22). Even if it is all working correctly, the next time the session is opened some of the plugin input selections are inactive (greyed and in italics). If I try to re-select the input (in this case plugin input 21+22) the input selection bumps to some other input, like 59+60. No matter what I do, I can not select input 21+22 on that track. If I delete the VEPro instance, insert a new one and then reconnect all the inputs it will work, until the PT session is closed and reopened and then the same problem occurs. I've replicated this situation on 2 different computers. Cheers, SK |
This is one of the reasons why I stopped trying to use Instrument tracks and went back to Audio tracks. This exact bug you're describing would show up on occasion and it was entirely frustrating. I believe that we used to fix the issue by creating a new Audio track and copying the VI plugin to that track. There might be some added maintenance to get the routing correct after the move.
I haven't tried PT12 but assumed that it would be fixed by now. Sounds like it remains. |
If you uncheck "input assignments" when you import your multi output tracks you'll need to reassign the inputs but you won't get this bug. Waiting patiently for a fix!!
Thanks everyone, at least I know it's a bug.
I'll swap out the instrument tracks for midi/aux pairs and see if that works. Cheers, SK |
Re: Instrument Track Plug In Input Bug
I'm seeing this problem a lot with students moving between Pro Tools 11 and 12.4 computers at school. Has anybody figured out the best workaround for dealing with this?
I really hope Avid fixes this for 12.5.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Instrument input stereo on the fast track? | eddiebrumley | Pro Tools M-Powered (Win) | 0 | 11-08-2011 08:05 AM |
Instrument Track Input problem | typhy | macOS | 1 | 10-04-2011 09:12 AM |
Instrument track doesn't register midi input in 7.4 | Teolin | MIDI | 3 | 01-21-2008 03:11 PM |
will not receive input signal on instrument track | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-03-2006 12:13 PM |
instrument track or aux input track | oreo1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-26-2006 06:10 PM |
