Old 04-16-2014, 03:30 PM
idris idris is offline
Default OMF files instead of WAVs
I've noticed some of the audio files listed in a session's Project Browser are listed as OMF files, rather than WAVs.
I'm pretty sure this can happen when importing session data from an OMF and selecting "Link to source media when possible". (It might be a mistake I've made or that of various other people.)
The session seems to run OK, but I was wondering whether there are any problems in store as a result, and if so, what the solution is? Can these files be easily converted to WAVs and does it matter?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 04-16-2014, 05:23 PM
alexeymohr alexeymohr is offline
Default Re: OMF files instead of WAVs
Depending on your workflow, this may actually be a good thing.
But generally I prefer to convert everything to broadcast wave in order to keep it clean. The easiest solution is to select "force to target session format" as your audio import option when initially opening the OMF.
If it's too late for that, you can always choose "Save Copy In..." and select "all audio files" and .WAV format and then check the box for "Convert to Specified Format."
I find it's best to keep all your audio elements in the exact same format if possible, in order to minimize compatibility issues and relinking issues.
- Alexey Mohr
https://www.parkstreetpost.com
Old 04-16-2014, 07:42 PM
reichman's Avatar
reichman reichman is offline
This works fine, but with a couple of drawbacks:
-pencil editing files that are embedded in the OMF is disallowed. If you need to do this, simply consolidate that clip and that will turn it into an independent audio file in the session folder.
-archiving the session by doing "Export Selected Tracks as New Session" seems buggy to me when dealing with embedded OMFs.
If you can afford the disk space and time, there are no serious drawbacks to "copying from source media."
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
HTML code is On
deleted wavs pinnacle macOS 5 09-04-2011 02:29 PM
.aif files to .wavs? digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-30-2010 11:19 AM
Plays imported wavs, records new wavs, BUT WON'T PLAY NEWLY RECORDED WAVs cmoseman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-02-2008 10:20 AM
converting SD2 files to wavs Darryn Farrugia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-17-2008 04:40 PM
help with wavs please!!!! Stashcom Digidesign Hardware & Software 1 02-14-2001 12:49 AM
