Old 12-03-2006, 03:37 AM
Moogens Moogens is offline
Default Projects between PC and Mac
I am just about to go from Steinbergs Nuendo to PT. Im doing postproduction for TV-programs.
I am working on PC, but about to buy Mac also.
Do you know if there are there any issues when moving PT-projects between MAC's and PC's?
Thank You!
Moogens
Old 12-03-2006, 08:23 AM
Brandonx1 Brandonx1 is offline
Default Re: Projects between PC and Mac
Hi Moogens,
Yes. You're going to run into may problems transferring session between Macs and PCs. Really there are only a couple of ways to transfer sessions successfully. This is how I do it. Normally, I get session of a mac formatted drive. If the session was made on a mac, you're safes to get mac HFS+ drives and mount them on your PC using Mac Drive 6. Then open the session from the mac drive and either just work from the mac drive or save the session using save session copy in function in PT. Hope this helps.
Peace,
Brandon
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 12-03-2006, 02:16 PM
airon airon is offline
Start all sessions with PC/Mac compatibility for starters.
You can "Save Session Copy" with that option as well. Test your setup thoroughly before using it for production. Digidesign is not known for flawless file management in its Protools software.
"My ego comes pre-shrunk" - Randy Thom
Old 12-03-2006, 09:03 PM
bigbadhenchman bigbadhenchman is offline
No matter what. The only way to guarntee that all the files you need will be int he session is to do what someoen else has said. "Save session copy as".
Select BWAV as the fiel format, and copy ALL files must be selected.
Also, enforce MAC-PC compatability.
Then you shoudl be fine.
M-Powered Forum
www.markhensley.tv
Old 12-03-2006, 11:07 PM
Starcrash Starcrash is offline
This is no longer an option in 7.x as it's always enforced now. Maybe they couldn't find a way to fix their spelling so they dropped it. I always got a little chuckle because they had it spelled "compaibility" on the New Session dialog.
Pascal Garneau | IMDb
Old 12-04-2006, 12:45 AM
I thought 7.2 on PT is even able to directly record to a HFS+ volume. At least it´s advertised.
frank.
HTML code is On
Trouble with old projects keithaska 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-07-2009 02:34 PM
Hands on projects where? Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-07-2009 06:01 PM
How to Archive projects porkipine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-16-2006 11:38 AM
crash on projects going from 7.1 HD to 7.1 M or LE jeff markham Pro Tools TDM Systems (Win) 2 04-02-2006 10:00 AM
Projects from TDM>LE>TDM>LE etc... jibberia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-23-2003 01:10 AM
