Old 03-25-2015, 05:45 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Default Audio Durations in TV Commercials
Hey Guys, Currently in Australia every tvc going on free to air tv is required to have half a second of silence at the front and back. (So a 30sec advert has 29 seconds of audio).
I was just wondering if this was a universal style requirement in other countries?
I'm feeling this is a pretty outdated requirement, as I believe it is legacy of some sort of analog workflow.
Cheers
Dave
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 03-25-2015, 06:15 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Audio Durations in TV Commercials
Back in the day of film commercials, there was one second of silence at the head because it took 24 frames to get to the sound after the spot started since it took 24 frames to get to the audio after the picture started.
And at the tail, picture would end one second before sound. Usually, audio fade would match picture.
It comes down to the splice point. Cut the picture and you cut the sound 24 frames later since it takes one second for the splice to get to the sound head.
Why someone would make a hard rule is a mystery to me. There is no rule like that in the States.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 03-25-2015, 06:19 PM
Leverson Leverson is offline
I think this is only an Australian thing. I've had to do it before when mixing TV commercials for Australian broadcast and thought it was odd. I've never seen that requirement for any other country I've had to deliver to though.
Old 03-25-2015, 06:39 PM
Arrow Re: Audio Durations in TV Commercials
I have seen this for deliverables sent to the U.K.
Old 03-25-2015, 07:43 PM
spoons's Avatar
spoons spoons is offline
The UK still has this convention I believe. 6 frames of silence top and tail with no critical audio with in 12 frames of the top and tail.
I think this was originally used to define the start and end of each Ad in an Ad break. So it was clear when one ended and next started. In fact I think I'm right in saying that there used to also be a logo 'blip' between each Ad on ITV but that was dropped.
Being a UK expat in the US it's still seems odd to me that Ads here run seamlessly.
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 03-26-2015, 06:23 AM
you kay you kay is offline
If you have a v/o up to the last frame of ad1 and the next v/o starts on frame one on ad2 surely the ads are going to sound like they clash.
Old 03-26-2015, 10:46 AM
When editing for TV, I would start a 10 frame dissolve from black at 1:00:00:00 and fade to black starting at 1:00:29:20 for 10 frames. The next spot would start at 1:00:00:30. Audio usually followed the picture dissolve or might be a hard cut at 10 frames in.
Park
Old 03-27-2015, 03:14 AM
Petevsi Petevsi is offline
Hiya
It used to be the first and last 12 frames where mute for UK ads, resently that changed to 6 frames mute front and end. That said I have had to deliver ads that where full length from first to last frame of video for some HD broadcasters so I tend to make sure the VO starts at lease 12 frames in to prevent it crashing with other ads.
If you look up the AdStream spec sheet for deliverable it lists there requirement for each country which is really helpful since it seams everyone wants something different :)
Pete
MacPros, GBLabs Space, S1, Dock,
MTRX, Dante, Protools HDX, VoiceQ
www.vsi.tv
Old 03-27-2015, 11:25 AM
mbauer1 mbauer1 is offline
I've been the states the past 7 years but spent the first 10 years of my career in Australia mixing commercials.
The rule is old and outdated.
It comes from when commercials and programs were played back from tape.
The ruling was for a 25fps commercial, you needed a half second of silence at the top and tail (12 frames approx)
You could get away with non essential information pushing as far as 6 frames either side, but not dialogue.
I don't know why the ruling still exists, for digital playback it's not needed.
Matt Bauer
www.bauer.net.au
E: [email protected]
Old 03-30-2015, 10:15 AM
Tstein Tstein is offline
We used to have a similar convention in the States many years ago. A 30 Second spot was 29.5 sec, a 60 ( yes we used to do 60's) was 59.5 sec,... This was done away with when the advertisers realized they were paying for a half a second of silence!
HTML code is On
midi recording - note durations busk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-11-2011 08:51 AM
Confused about MP3 file durations Peter Groom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 04-14-2006 01:33 AM
very cool QT helper to change ratio and durations Frank Kruse Post - Surround - Video 12 10-12-2005 12:58 PM
Hi-Def Commercials spigots Post - Surround - Video 2 10-22-2004 08:40 PM
Commercials *DELETED* greggy General Discussion 1 09-03-2004 03:49 PM
