Re-setting output path
Very new (yesterday) to Pro Tools and new to the forum too. Hello! Importing sessions created on an HD system, PT8LE is changing the inputs and outputs, so I can't hear anything. The demo song works just fine. How do I change these inputs/outputs so I can hear the sessions? Most output (interface) options on the mixer just say "path n/a" Of the bus options, only "Reverb" is in yellow. Thanks in advance. Irvin |
Re: Re-setting output path
Go to Setup > I/O > Click on Output Tab and click on Default, that should make PT assume your interface outputs.
Brilliant thanks. After I did that, the stereo output of the micro showed up in the mixer.
Cheers! Irvin. |
the output could not be made active because the output path is currently made inactiv | rosebartu | Pro Tools M-Powered (Mac) | 4 | 03-21-2018 12:28 PM |
Is there a VST path setting in PT10? | Scorepio | Windows | 2 | 07-09-2012 03:47 AM |
What is a good output path? | mij sang | Tips & Tricks | 12 | 01-20-2009 06:02 AM |
5.1 output path not available? | 316 | Post - Surround - Video | 2 | 12-06-2007 11:52 AM |
Busses as output path destinations? | AE | Pro Tools TDM Systems (Mac) | 0 | 04-16-2007 02:18 PM |
